Video Capture Has No Audio at DVinfo.net
Open DV Discussion
Old February 1st, 2012, 05:07 AM   #1
I transferred a VHS tape to miniDV, then attempted to capture the video via firewire.
The audio did not transfer.
On the camcorder, the audio appears fine.
Other miniDV tapes capture fine.
Any ideas?
Thanks...Alan
Alan Henderson is offline   Reply With Quote
Old February 1st, 2012, 08:54 AM   #2
Re: Video Capture Has No Audio
Hi Alan,
You don't mention which DV camera you have. While 48k is the standard for DV audio, some cameras can also capture 32k audio. Maybe your VHS transfer is 32k and therefore not capturing with the NLE set to 48k? Your NLE setup should offer both - try the 32k capture setting once and see what happens.
Jeff Pulera
Safe Harbor Computers
Old February 1st, 2012, 04:05 PM   #3
I'm using a Canon ZR200.
I've tried WinDV, VirtualDub and Vegas 8.0.
VirtualDud is the only one where I see what the audio is set at (32000).
For the other two, I see no audio options.
Alan
