Lithium ion batteries got wet at DVinfo.net
Open DV Discussion
Old September 17th, 2011, 05:08 PM   #1
I had two batteries for a pd-170 in a case in my car. The floor somehow got wet. I'm not sure how. They weren't submerged, but there was enough water to waterlog the spines of a few books that were down there with it. I'm not sure whether the batteries got water inside although I suspect it may be the case. The batteries were wet on the outside. I"m not sure how long they may have been exposed to the water.
Safe to plug in to the charger and see if they charge? I'm concerned. And these were my only two good batteries. One was brand new, never used, only charged.
one was a sony 960, the other new one was an off-brand that is supposedly equivalent.
Thanks in advance.
Kell Smith is offline   Reply With Quote
Old September 17th, 2011, 06:13 PM   #2
Re: Lithium ion batteries got wet
Personally, I wouldn't trust them. What could go wrong? Well, they could rupture (bad!), short out your charger (bad), catch fire (REALLY bad), or work properly for now (good).
I don't like those odds, given the (relatively) low investment cost involved.
Old September 17th, 2011, 09:07 PM   #3
I'm concerned because these are my only batteries (the other two died recently), and I really don't have the funds to replace them just yet. Too many bills. Is there any option? I am not sure if they got wet inside or not. What's the chance they are a fire risk?
Old September 17th, 2011, 09:20 PM   #4
I've seen positive reports using this method ..
How to Save a Wet Cell Phone or Camera Battery | eHow.com
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
Old September 17th, 2011, 10:04 PM   #5
THanks I'll try it
I don't have any silica packets but I'll try the rice.
That casing looks pretty tight. If moisture got in there I"mnot sure if it will find its way out.
Mostly I'm concerned about a fire hazard.
Ok, let's see if this works. Here goes.
Old December 19th, 2011, 05:36 PM   #6
Forgot to post back, but the battery is working properly and holding charge.
