manual zoom lens motor attachment? at DVinfo.net
Open DV Discussion
Old August 17th, 2011, 12:49 PM   #1
I've been searching for this but haven't found anything:
aren't there external variable speed motors that can be mounted side by side with a lens in order to convert a manual zoom into a powered zoom? I don't know what they're called ~
any reference is appreciated!
Robert Bobson is offline   Reply With Quote
Old August 17th, 2011, 01:22 PM   #2
Re: manual zoom lens motor attachment?
There are a number of makes including Heden, Preston and Arri, but a zoom servo motor or zoom motor would cover what you're describing. These are now digital motors that are controlled by a separate control used by either the camera operator or the 1st camera assistant.
Preston Cinema Systems
HEDN Engineering
ARRI Group: Controlled Lens Motor CLM-3
Old August 17th, 2011, 04:36 PM   #3
thanks for the info. are there also attachments that can help make the manual zoom smoother? I'm thinking like a geared crank that would take several revolutions to zoom the lens just a small bit?
Old August 17th, 2011, 04:57 PM   #4
You can get a fluid drive for zoom lenses. these are made by Chrosziel and work extremely well. Some of the old 1960s & 70s Angenieux zoom lenses had a zoom crank fitted, although I found these devices rather underwhelming to use on the couple of occasions I came across them.
Brian Drysdale is offline   Reply
