Editing: Need examples of "Handoff" transitions... at DVinfo.net
Open DV Discussion
Old July 21st, 2011, 02:43 PM   #1
I'm working on a project where we want to use a similar technique for transitioning from one scene to the next as what is used in this movie trailer...
Snatch Opening Title Sequence
I know I've see other examples of this kind of transition, but several of us have literally spent a few hours doing searches on Google and Vimeo and YouTube and can't find them! (It's somewhat maddening, because we KNOW they're out there!)
The concept at it's simplest level is using an object in one scene to serve as a kind of "wipe" to the next scene. Getting more complex, objects can be thrown out of frame, landing in the next scene, etc.
I've seen some incredibly creative examples of this sort of thing...so if anyone knows of any and can post some links, I'd be grateful!
Scott
Scott Wilkinson is offline   Reply With Quote
Old July 21st, 2011, 02:49 PM   #2
Re: Editing: Need examples of "Handoff" transitions...
What they did, most likely, was composite shots together that were intentionally framed and shot to be used like that.
Diamond facing the same way, with a shallow DOF that softens the BG enough that you can barely realize the cross dissolve that happens while the shot is turning.
When it comes to the others, same thing - shot intentionally to be used like they did. This would be a job for after effects. You would line up the shots together on a comp, and just do a camera movement or just slide the two pieces of footage over while masking over to the next shot with a feather so it looks smooth. I could see roto being used in this as well.
Justin Molush is offline   Reply With Quote
Old July 21st, 2011, 02:57 PM   #3
Yep, I agree Justin---that would be one way of doing it. In our case, we're shooting a series of "walking feet" stepping through a variety of scenes (relatively closeup shots of feet walking)...and want to use these type of handoffs between them.
It definitely requires a lot of advance planning and working out the precise flow from one scene to the next (along with what the transitional element will be).
But I want more examples! :-) (Like I said, I know they're out there---lots of videos have done this.)
Scott
