Upgrading to HD from PD-170 - Page 2 at DVinfo.net
Open DV Discussion
Old January 25th, 2011, 04:47 AM   #16
Ah - it sounds like you're not comparing 1440 x 1080 HDV footage to SD 720 x 576, you're comparing down-converted Z1 and A1 footage to the PD170 and XM2 - is that what you mean?
In that case, I can go along with you - and certainly in the 4:3 mode. My VX2k produced some quite startlingly sharp footage whereas the on-board, 4/11d Z1 down-converter makes SD tapes that are on the good side of so-so.
You say you edited a project that used footage from all the cameras - so was this a 4:3 or 16:9 production?
I shot a wedding as second camera, using my Z1 in SD mode (effectively doing the down-conversion on the fly between chips and tape). My pal used his 170 in the 16:9 mode and know what? We simply couldn't A / B cut them together, the 170 looked so soft. Looks ok letterboxed on a 4:3 CRT, but when upscalled as a DVD into a big LCD TV - no way.
tom.
Old January 25th, 2011, 07:39 PM   #17
From PD170 to Z1's
I too, moved from a 170 to Z1's and thought the Z1 picture (in SD of course) was just a touch softer than 170. But still was happy with my purchase. HOWEVER, I will be listing my Z1's for sale because, for me, it is time go solid state. I have an EX1R that is my primary camera and the speed in which I can load onto the computer is great. For me, it's like going from manually changing the channel to a remote control.
Bill Rankin
Bill Rankin is offline   Reply With Quote
Old January 26th, 2011, 01:19 PM   #18
Tom - yes I am talking about 4:3. Mind you 16:9 HD images were cropped rather then letterboxed in the down conversion, and not shot in 4:3 - I found particularly that the A1's SD 4:3 mode was horrible and the Z1's not much better. And yes 16:9 in a native 4:3 SD camera is pretty horrible too; don't know any native 16:9 SD cameras personally.
Mind you it's not just the softness that's the issue for me with the Z1 - I dunno maybe I was just not using it right but it tended to produce nasty coloured edges in certain light too.
Geoffrey Cox is offline   Reply With Quote
Old January 26th, 2011, 03:55 PM   #19
Thanks guys for all the feedback. I have also heard the Z1U has a softer picture. I had it down to a XH-A1 or Z1U. WIth the ratings both good for each one, albeit more leaning towards the A1 vs the Z1U, the price of the sony was the deciding factor for now.
Once i get the Z1U and if I am not satisifed with it, i will switch out for the XHA1. I know a local producer that uses them and he prefers them over the z1u's. I would like to stick with sony, but for the price the XHA1 looks like a nice camera too, and newer, mind you i would still have to buy used. If i was only buying one i could probably buy new, but i need 2 cameras all the time atleast.
Would make sense to have one of each to have the best of both worlds? I rarely do 2 camera shoots, but I do some local sports online and the scattered 2 camera shoots for dvd or the web. I'm guessing a z1u and a xha1 would be a bit tricky to match up in post.
Mark
Mark Chafe is offline   Reply With Quote
Old January 26th, 2011, 05:44 PM   #20
If your mood swings toward the XH-A1 drop me a line. I have one with low hours and wide angle lens that I really haven't used much since we got the Red. I have kept it around since it's such a nice little camera, but have since bought an AF100 for second camera work.
Good Luck!
Dave
David W. Jones
www.joneshdfilms.com
Old January 27th, 2011, 02:21 AM   #21
It's something that I'd avoid, if only because of the different batteries and chargers you'll have lying about. Also, as you run to your car for your backup cam when nr 1 cam has seized up, your brain will have to switch into nr2 cam mode, with all the changes and differences that entails.
I can't see that matching up in post will be a problem.
tom.
Old January 27th, 2011, 02:51 AM   #22
Mark - had to do exactly that in a recent project all shot on a Z1 and A1 - colour matching was OK (actually set the A1 to match the Z1 in camera) but matching the general look was difficult due the aforementioned softness of the Z1.
