Triple monitor setup - need some help please at DVinfo.net
Open DV Discussion
Old January 12th, 2011, 05:17 PM   #1
I want to buy three 28 inch monitors, turn them sideways (90 degrees) and place them together and create a triptych type of setup. Can anyone get me started on :
Something like this image : http://www.intermix.org.uk/images/in...e/triptych.jpg
1) What hardware I am going to need (besides the three monitors)
2) What software I will need to run videos and the like in this setup.
Thanks in advance.
David Delaney is offline   Reply With Quote
Old January 12th, 2011, 06:47 PM   #2
Besides the monitors, you will need a mount. Ergotron makes just about any mount you need: Ergotron Products>Multi-Monitor
You'll also need a graphics card with 3 outputs, or one with two outputs and one with one output. The rest should just be system settings to get the monitors arranged properly.
Edward Carlson is offline   Reply With Quote
Old January 13th, 2011, 08:58 PM   #3
Thanks for that, I was thinking about building a mount so they could go sideways. Now, a bigger questions is how can I turn the video's I am showing, sideways so they show up properly on the 90 degree turned monitors?
Old January 13th, 2011, 09:02 PM   #4
In Mac (and probably Windows, too) there's an option to rotate the display. So instead of having a 1024 x 768 resolution, you have a 768 x 1024 resolution. If it's not under Control Panel > Displays in Windows, check for the graphics card driver program, I know NVIDIA has its own. In Mac OS it can be found in System Preferences > Displays, Rotation menu.
