Which Video camera should I get - Page 2 at DVinfo.net
Open DV Discussion
Old December 24th, 2010, 07:21 PM   #16
Originally Posted by Pete Bauer View Post
The opposite is true; AVCHD (h.264/mpeg4) is much more efficient compression than HDV (mpeg 2). So at similar bit rates, AVCHD will have much less visible artifacting than HDV. Compression is roughly twice as efficient as MPEG-2.
That said, the industry has excellent implementations of both.
I agree with that statement. Generally speaking, however, HDV's compression is less efficient than AVC compression. Thus, the bit rate of HDV (or any other form of MPEG-2 compression) actually needs to be relatively high just to avoid looking totally craptastic.
In the cheaper consumer HD camcorders, the limiting factor is not the recording format - but the sensor itself. Some of the sensors in the cheapest Sony HD camcorders do not capture the full 2MP resolution of 1080p video (but since they record only interlaced video, 1.35MP is more than adequate other than the fact that these tiny sensors are mediocre at best in low-light performance).
However, since the two camcorders mentioned are "prosumer" models, the performace from either should be "relatively" good.
Randall Leong is offline   Reply With Quote
Old December 25th, 2010, 04:45 PM   #17
Randal, Stellios,
thank you for the information on the compression issue.
How does that work??? I was only looking at the numbers.
I know things are improving all the time, a while back I was looking at a jvc with a hard drive a friend shot with and must say I felt the image was not up to snuff.
thank you for sharing!!!
dale
DATS ALL FOLKS
Dale W. Guthormsen
Old December 26th, 2010, 11:53 AM   #18
I own a Sony Z5 and it's great, for many jobs tape can still be very important. That said I do wish I had the CF card recorder for it as sometimes the faster transfer speeds could be handy.
The great thing about that combo is it gives you the best of both worlds, that said for the price of the combo I think its worth paying out for a Z7 instead, its got far better build quality and it comes with the CF card recorder.
Lastly if you can really push a bit more for an EX1 then that's the option I would go for. Despite being happy with my Z5 in some ways I do wish I could have afforded the little bit more for the EX1 as its a hell of an upgrade from the Z5.
Only other factor to consider is editing. Out of all HD formats HDV is the easiest to edit, doesnt require as powerful computer as XDCAM or AVCHD. That said if you have an i7 computer it should edit any of these formats easily.
Jonathan Palfrey is offline   Reply
