Neat Video vs. Magic Bullet Denoiser at DVinfo.net
Open DV Discussion
Old November 16th, 2010, 11:53 AM   #1
Anyone have a preference between the two that has used both? Also, Neat is available for both Premiere and After Effects. Which is the ideal platform? I would imagine Premiere, as that's where I spend the bulk of editing time, unless I'm overlooking something.
Patrick Janka is offline   Reply With Quote
Old November 17th, 2010, 09:39 AM   #2
I use Neat on PPro. I believe, though, that once you buy a license you can use it on both PPro and After Effects. I haven't had a need to use it on After Effects so I can't answer for sure.
Neat has radically improved their process over the last year. A year ago I remember battling with finding a frame having a sufficient blank space to get my noise profile from. The updated version makes it clean and simple. You know right away if the frame selected will give you a good profile or not.
I'm still using CS3 so I only have been using the 32-bit version. I am runnning a dual-boot configuration with Win7 and CS5 installed but am waiting to swap out video cards for an MPE qualifying Nvidea card. I use Matrox RT.X2 which has not released its drivers for CS5 yet. I am hoping that in CS5 with a high performance Nvidea card and the 64-bit version of Neat installed, that the crank times will go down radically. In CS3 a simple timeline can crank for hours with the Neat denoise effect added.
Wesley Cardone
www.WCardoneProductions.com, Detroit and Lansing, Michigan
Wesley Cardone is offline   Reply
