90 minutes of HQ mpeg on DVD possible? at DVinfo.net
Open DV Discussion
Old August 25th, 2010, 07:20 AM   #1
Hello all, I am learning (slowly I am afraid) and doing a lot of trial and error which leads to my question today. Can I get 80-90 minutes of HQ mpeg (DVD quality) footage on a single layer DVD? When I render to SP mpeg and burn, I can see the difference between that and a HQ mpeg burned to a DL disc.
Thanks all.
Darryn Carroll is offline   Reply With Quote
Old August 25th, 2010, 09:06 AM   #2
I too am going through that same learning process.
Going from HD to SD is all about how the transcoding is done.
I start with Panasonic 60p, import into Edius Neo Booster, export as AVI, import into TMPGEnc, export out as .mp2 and .m2v files.
Then you have to create the DVD files/folders, then burn to DVD.
Yes, it is ridiculous how many steps it takes to do this.
Even though I am struggling with the audio portion of my DVD creation, the video portion looks excellent.
Others on this forum suggested all the software I am using.
Now to your question of will it fit?
I'm sure you can make it fit, how it might look is a different story.
From what I have read, most people say 60-80 minutes is the maximum you should shoot for.
Alan
Alan Henderson is offline   Reply With Quote
Old August 25th, 2010, 09:16 AM   #3
Thanks Alan,
I think I need to try my hardest to get these finished projects down to 60 minutes!
Old August 25th, 2010, 08:01 PM   #4
Darryn, check out this bitrate calculator:
Bitrate Calculator
You can see that at 90 minutes, you can still encode at about 6500 kbit/s with audio at 256. This should give a pretty good result if you use multipass variable bitrate encoding.
I usually see 90 minutes as about being the limit, however. Past that, your bitrate starts to drop alarmingly. For example, at 1 hour 45, you're down to about 5500. The sweet spot is about 80 minutes, where you are over 7000, approaching the max of what you would want to use anyway.
http://www.nosmallroles.com
Vito DeFilippo is offline   Reply
