Raid 0 question at DVinfo.net
Open DV Discussion
Old January 25th, 2010, 04:25 PM   #1
Raid 0 question
I was wondering if I could purchase a pci e raid controller card as follows:
Sabrent Serial SATA II 3Gbps 2-Channel 4-Port RAID & SATA II PCI Express Host Controller Card at TigerDirect.com
Use a dual docking station e sata, run raid 0 in the station and run my program and such through my desktop hard drive as a standard sata hard drive?
this card would give me three e sata ports, two through the card and one through the desktop. I assume that the desktop one would not be raid 0 as it doesn't run through the card.
would that be a reasonable configuration?? or would the non raid be a problem and should not be used if you are using the ports on the card?
My computer is aDell xps studio workstation with an I7 processor, 64 bit vista, 6gigs of ram.
Dale Guthormsen
DATS ALL FOLKS
Dale W. Guthormsen
Old January 28th, 2010, 01:28 PM   #2
Hi Dale.
First, I have had no experience with this card.
Clearly you want to get the benefit of read/write speed by using RAID 0 (striped). I see by your gear list you're running Vegas and Prem Pro (1.5) - and Intel I7 quad core. I run Prem Pro CS4 with a similar setup (but more RAM and storage) using Asus P6T MoBo.
I followed the product link you provided and alarms started sounding when I saw a review of this card. Yes, for $20 it appears to be good value, giving you two additional EXTERNAL e ports for your RAID Disks.
But personally, if someone is already running Vista 64 (as you say) and a reviewer says they have had problems with this card with Vista drivers, I'd think twice.
But that's just me... Hopefully, someone else might like to offer some advice, but it's a $20 card. Provided it's shipped (or upgradeable) with the right drivers, then fine - if not, beware :)
Women don't hit harder, they just hit lower!
Claire Buckley is offline   Reply With Quote
Old January 29th, 2010, 12:28 PM   #3
Claire,
I missed the review about the cista issue, will pass.
As it turns out my computer is raid ready on its own, so I only need the docking station that can run the raid, that is easy.
will probably have numerous questions later!!!
thank you for taking the time!!!!
dale
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
