Blue outline on bright whiteness
I get it all the time on my photographs. Can someone explain what it is exactly and how to avoid it?
Probably CA does it happen at full telephoto mostly? What kind of camera and lens?
CA - chromatic Arborhition ( not sure on the spelling) |
Could also be in-camera sharpening and/or compression artifacts. Kyle, can you post a picture that shows it?
Pete Bauer The most beautiful thing we can experience is the mysterious. It is the source of all true art and science. Albert Einstein Trying to solve a DV mystery? You may find the answer behind the SEARCH function ... or be able to join a discussion already in progress! |
#5 |
Equal Opportunity Offender
Pixel bleed - where there is too much light compared to surrounding pixels and (electronically) some spillage occurs.
Or it could be a chromatic aberration issue as per above. Andrew PS. Really could do with a still image to view. |
#6 |
Or maybe there was a bluebird streaking through the frame:<)
Anyhow, as others are saying, could be a lot of things and without seeing it it's awfully hard to know what is causing it. |
#7 |
. . . like even stripe filter color seperation stuff to achieve color from a single chip
more cheap tricks that i dont totally understand.
----------------sig----------------- Re-learning everything all over again, one more time. |
#8 |
Did your camera cost more or less than $29.95? ;-)
