November 10th, 2009, 06:34 AM | #1 |
Rather special lenses - anybody used them?
Hi all,
On eBay I came across a cóuple of (for me at least) rather special lenses. They haven't arrived yet, but I thought I would like to have your ideas about them - usefullness etc. 1. is a FUJINON Lens RCV-82SC A20x8.6 ENG Converter 16:9 - ie. a lens that converts a "normal" 4:3 lens to a true 16:9 lens. Question is - will there be any difference at all? I'm using a JVC 5101 camera, which only have 4:3, but have a special "squeeze" mode. allowing you to do artificial 16:9. 2. The other lens is FUJINON 0.75 wide angle converter. Bought it together with a lens (FUJINON S14X7.3BRM4), but plan to use the wide angle converter on my 20x lens on the JVC camera. OR - should I just keep the wide adapter on the 14x lens and use that lens with converter, when need for wide shots arise....? Any ideas or insights ? Kind regardxs Peter |
November 10th, 2009, 03:28 PM | #2 |
The 16:9 converter sounds like a an anamorphic lens. It will optically "squeeze" the image from left to right. The result will be a 16:9 image which fits into a 4:3 frame. If you correctly flag the clips as anamorphic 16:9 in your editing software, you should get high quality 16:9.
These lenses can be difficult to use though. They have to be correctly aligned and may not support full zoom-through focus. |
November 11th, 2009, 08:56 AM | #3 |
Hi Boyd,
Sounds really good. I got it for a very good price (USD 299 compared to B&H's price of USD 1000+), so it will be very interesting to see the result. I HAVE noticed, that when I change the JVC DV5101 from 16:9 squeeze modt to 4:3, I get a much wider pic in the viewfinder. Software squeezing is OK, but nothing beats a good piece of glass! Thanks for the info. I will have it in a weeks time, and let you know the outcome. /peter |
