Ultra thin UV-Filter
Hi: Looking for an u l t r a t h i n 95mm UV- or clear-filter designed to avoid vignetting - and at a considerable price as I am still washing dishes.
Anybody has a hot hint? Thanx! |
Tough call, B+W have ultrathins but they cost.
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
Schneider makes thin filters but they usually cost $100+
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/ |
Sorry. No free lunch here either. If you tell us the camera you want to use it on, perhaps someone can recommend a not-so-thin and not-so-expensive filter that will work without vignetting.
#5 |
Hi:
Wanna use that filter on the FUJINON wide-angle XS8X4AS-XB8 of my Sony EX3. |
#6 |
Why add a UV filter? The lens itself will absorb all the UV light you throw at it.
Mechanical protection? You're going to be filming sail-boarders on wind-swept, sandy beaches? OK, fit a filter. Or you're shooting weddings on sun-lit, gentle lawns? Forget the filter, they cause more trouble than they're worth, and the smaller the chips (= the shorter the focal length) the bigger the problems you'll face, especially into the light. tom. |
#7 |
Step-up ring + normal filter
Consider getting a 95 to 105 step-up ring. Then just get a regular 105 filter. Should save you some money.
Ken |
