Super 8 movies to video? at DVinfo.net
Open DV Discussion
Old October 11th, 2009, 08:22 AM   #1
I am new to video and could use any help you can give.I thinking of getting a Canon HF20, one of the things I would like to do with this camera is capture some old Super 8 sound movies. I would like to run the movies and capture them off of the screen, would this be the right way to do this? Would there be a frame rate problem between the two formats? Would the Canon HF20 work for this?
Glenn Oberlin is offline   Reply With Quote
Old October 11th, 2009, 09:05 AM   #2
8mm Film to DVD transfer (Do it yourself) - Photo.net Video Forum
I gather the most import part is getting a quality projector.
Old October 13th, 2009, 03:55 PM   #3
glenn,
If you still have a super 8 camera to play the old tapes you can buy a product called "Dazzle" basically converts analog straight from the camera, converts to digital to your computer. I also have a samsung VHS/DVD recorder (model VR357) that will do the same thing...you can record directly to dvd.
Hope this helps.
Michael Hutson is offline   Reply With Quote
Old October 13th, 2009, 04:11 PM   #4
I think maybe you're thinking of 8mm or Hi8 video, not film, as we're discussing here. Super 8 is a film format, not tape. With film, you don't play it in a camera -- you need a projector. And you can't stick a cable into either a film camera or a film projector. I mean, you could, but it wouldn't do anything...
Old October 13th, 2009, 05:51 PM   #5
This may prove helpful:
Super-8 Filmmaking in the Digital Age!-Super-8 is Thriving in the Digital Age!
Old October 13th, 2009, 11:24 PM   #6
If you decide to go low-tech and film a projected image off a wall, or whatever, Virtualdub's hotspot filter is worth investigating to help even out the lighting: Hotspot Filter for VirtualDub
Old October 15th, 2009, 05:13 PM   #7
Thanks for the info
Thanks for in information I'll check it out ........... Glenn
