Good lens cleaner needed at DVinfo.net
Open DV Discussion
Old June 11th, 2005, 09:51 AM   #1
I bought a nock off brand lens cleaner w/my Gl2. I used it once and all it did was create more streaks. What's a good lens cleaner i can get for <$50 from B&H. Also if you could guide me in the right direction of where to buy compresses air cans locally, like at the hardware store?
Eric Hess is offline   Reply With Quote
Old June 11th, 2005, 10:00 AM   #2
Costco sells 6 can packs (air)
Dan Diaconu is offline   Reply With Quote
Old June 11th, 2005, 01:52 PM   #3
I used to use those lens cleaning cloths from opticians but I have started to use a lens pen and find that it does a superior job; cost £8 from Jessops camera store.
Colvin Eccleston is offline   Reply With Quote
Old June 11th, 2005, 02:59 PM   #4
For a lens brush I would just go with the 'General Brand" pick one you like.
I have used Edwal lens cleaner for many many years.
I have used the Kalt cleaning colth for the last 3-4 years.
Should cost you around $15.
I do not know about buying compressed air from a hardware store.
I would not do it, my lenes are worth more to me than cheaper air.
http://www.bhphotovideo.com/bnh/cont...arch&Q=&ci=429
Blower Brushes $3.95 - $4.95
http://www.bhphotovideo.com/bnh/cont...x=4&image.y=11
Edwall Lens Cleaner $4.95
http://www.bhphotovideo.com/bnh/cont...=16&Submit.y=8
Kalt Micro Fiber Optic Cleaning Cloth $3.95
http://www.bhphotovideo.com/bnh/cont...=188337&is=REG
Cinematographers Bring Shadow To Light
Bill Hamell is offline   Reply With Quote
Old June 11th, 2005, 06:51 PM   #5
I'm a still photog who plays with DV toys from time to time. I've used many lens cleaners over the years, and ROR (Residual Oil Remover) with a microfiber cloth is the best lens cleaner I've used. Last I checked, B&H sells it. A lenspen is good if you are obsessive compulsive and need to get the very edges of the lens element or filter that you can't reach with a cloth. But use the ROR first.
Brian Kennedy
Brian Kennedy is offline   Reply With Quote
Old June 16th, 2005, 09:40 PM   #6
We use the Bauch & Lomb disposable lens wipes that you can get from Costco. Tried the Zeiss ones but they don't work as well -- too much moistener. Under cold conditions it's slow to evaporate.
Takes off smudges nicely. For the environment we're in, we end up wiping the lens a lot. The microfiber cloths work very well but you have to remember to wash them, or you'll eventually end up putting back the stuff you wiped off.
Dean Sensui
Old June 16th, 2005, 10:49 PM   #7
I am able to clean my lenses as well as my monitor screens very effectively with a microfiber cloth. Not an expensive one from a camera store, but a
3M microfiber general-purpose cleaning cloth from a grocery store. It costs about $4. and is 1 sq. ft. in size. It is soft and durable and works better than a $15. one I have, that was made specially for lenses, that is only 1/8 sq. ft. I rarely have to use any fluid with the 3M one and I cut it into 8 pieces.
J. Stephen McDonald is offline   Reply
