Posts: n/a
Sony camcorders
I have 2 camcorders TRV65E Hi8, and a TRV17E DV, with dv in and out enabled, question, can the Hi8 tapes be transfered to the DV camcorder just using the 2 camcorders and how, using what.
You need "analog in" enabled (Y/C or composite) on your DV camcorder.
Posts: n/a
many thxs Dre..... So now how do I enable analog in on the Sony DV.
I am not shure yr cam can be "enabled" for analog.. If there is no hardware for composite(or Y/C) to component conversion (needed for DV compression) this will be impossible. Check the cam specs.
#5 |
Another way is to locate a D8 camcorder that can view Hi* tapes (not all do). Then you can transfer to DV via firewire.
Nathan Gifford Southern Cyclist Magazine & Productions For quick answers try our Search! To see me and Rob Lohman click here |
