what about green component? at DVinfo.net
Open DV Discussion
Old April 10th, 2005, 01:02 PM   #1
Question: Can anyone explain to me in simple terms why when RGB signals are converted into Luminance (Y) and color difference
(R-Y)and (B-Y), There is no (G-Y)? Why is it done this way?
Steve Witt is offline   Reply With Quote
Old April 10th, 2005, 01:24 PM   #2
If you know that the Y signal is made out of (roughly) .3R+.6G+.1B and you know R-Y and B-Y you can calculte G-Y by simple substitution. In more practical terms: if you know what the R and B levels are (out of Y and R-Y and B-Y ), and you know the total luminance Y, you know how much of the G signal is needed to get that luminance.
Andre De Clercq is offline   Reply With Quote
Old April 10th, 2005, 07:02 PM   #3
Ok, but I thought Y=luminance. Sorry, still confused about this whole thing.
Old April 11th, 2005, 02:21 AM   #4
Indeed Steve, Y is luminance. In color camera's, incoming signals (also pure b&w scenes) are split out into 3 colors R, G and B. Each color represents a certain amount of luminance, and the total luminance signal(Y) is made out of a combination of 30% of the red signal, 59% of the green signal and 11% of the bleu signal. Bleu is e.g. a "dark" color for the human eye and so it only counts for 11% in the Y signal build up. In the above situation where we know the RGB values and the ratio in which they are present in the Y signal we get:
R-Y= .70R - .59G - .11B
G-Y= -.30R + .41G - .11B
B-Y= -.30R - .59B +.89B
Out of this we get:
G-Y = -.51 (R-Y) - .19 (B-Y)
This last expression means that G-Y is deductable from the R-Y and, B-Y values and so G-Y doesn't need to be transmitted.
Old April 11th, 2005, 08:45 AM   #5
thanks for the explanation Andre. It makes a little more sense now. I guess I need to brush up on my algebra.
Old April 11th, 2005, 03:55 PM   #6
It is quite possible to encode B-Y, R-Y and G-Y but if you are going to do that you might as well just use R, G, B. The reason it's done this way is so that brightness information can be separated from color information. The Y signal carries no information about the hue or saturation of the scene being transmitted - only its brightness. The R-Y and B-Y convey no information about brightness (ideally, in fact they do - a phenomenon called "luminance leakage"). There are several advantages to separating color and brightness. One is that a B&W picture can be transmitted or stored by using the Y component alone. In the NTSC system, for example, if only the Y component is demodulated you have a nicely toned black and white picture and this is the basis for compatibility. Another is that we perceive detail in the Y signal. This makes it possible to transmit/store the B-Y and R-Y signals with less bandwidth than the Y signal (in DV these channels are sampled at 1/4 the rate of the Y channel). A third is that it enables color saturation and hue adjustment without affecting brightness thus making color correction easy.
In fact in many color TV sets the G-Y signal is generated (or at least it was done this way in the old days in some designs). Then R-Y, B-Y and G-Y can be applied to the cathodes and Y to the grids resulting in beam currents proportional to R, G and B.
Old April 11th, 2005, 07:24 PM   #7
Thanks AJ, I appreciate the info.
