bit confused at DVinfo.net
Open DV Discussion
Old April 1st, 2005, 12:58 PM   #1
bit confused
I did a search on this but I am still struggling. When we are talking about "COLOR", what size bit system are we dealing with in Digital Video. 24bit or 8bit or what? The reason I even came across this subject is that I was doing research on GAMMA CURVES. look here to see what I have read.
http://www.siggraph.org/education/ma...n/palette.html
Does this bit value difference show up when comparing 3CCD cameras versus single CCD? Is this color bit value something we can control? Thankyou!!
Steve Witt is offline   Reply With Quote
Old April 2nd, 2005, 03:18 AM   #2
DV is 8bits/color, means a potential of 16 mio levels of 'gray'. No difference between single and 3ccd. Gamma in videocams is performed using higher bit levels after a first A/D conversion.
Andre De Clercq is offline   Reply With Quote
Old April 3rd, 2005, 05:25 PM   #3
Thanks Andre. What is A/D conversion? Thanks.
Old April 3rd, 2005, 08:09 PM   #4
Andre,
Wouldn't 8 bit/channel give you 2^8=256 levels of grey?
Not sure what mio means though.
The distinction has to be made between bits/channel and total bits. DV is 24 bits (8 per channel - RGB) IIRC so there is 2^24=16.8 million colours
Steve,
The signal from the camera's CCD is analogue. The camera then runs it through and A/D (analogue to digital) converter so the signal is then digital.
The gamma curve (when speaking in the context of video, DV, etc) is basically a graph of input value to output value and changes the colour response. You can reduce the brightness of highlights, crush blacks, etc.
This is often done in an NLE in post, but some cameras (the more high end ones) can do it in camera.
Someone correct me if I'm wrong.
Hope it helps.
Kyle Ringin is offline   Reply With Quote
Old April 3rd, 2005, 08:24 PM   #5
Many cameras have processors in them that determine the gamma curve/response of the camera. Cameras can perform this processing at higher bit-depths to avoid banding/rounding error.
Newer cameras tend towards higher bit processing for this.
(Sorry I don't think this makes sense.)
Old April 3rd, 2005, 08:41 PM   #6
Steve:
<< What is A/D conversion? >>
Analog to digital conversion.
Many folks are not aware that a CCD is an analog device which puts out an analog signal. This is converted to a digital bitstream by the A/D converter.
Oops, sorry Kyle, didn't see your previous explanation there. Nevermind the echo please.
Old April 3rd, 2005, 08:46 PM   #7
Thanks Kyle and Glenn & Chris. 24bits colour makes more sense to me. I do remember reading a little about the analog to digital conversion in DV cameras but I guess the A/D expression threw me. Are the 24bits always divided equally between the red, green and Blue? Thanks again.
Old April 3rd, 2005, 08:47 PM   #8
BTW my ramblings above about 24bit, etc were to do with the processing of the video in an NLE. It doesn't take into account 4:2:0 and 4:1:1 colour sampling of DV.
I'd recommend Adam Wilt's site for that:
http://www.adamwilt.com/DV.html
Old April 3rd, 2005, 09:00 PM   #9
Steve,
When talking about RGB colourspace the bits are divided up equally between the colours. The total number of bits may not be a multiple of three though (eg 16bit, 32bit), due to extra bits (usually 1 or 8) used for the alpha channel.
When processing video in an NLE each video frame is basically decoded into an uncompressed image, processed, then recompressed.
When speaking of the DV compressed video, the colour sampling business comes into it as well.
Old April 3rd, 2005, 09:21 PM   #10
thanks for the help Kyle. I'm trying to remember the name of a book I checked out from the library on digital movie making a couple of months ago. At the time it was a little too advanced for me so I took it back and got more basic level books to start off with. Anyway, this book covered this very subject we are discussing here and I believe if I got my hands on this book again, it would now make more sense. I think I am ready to go more indepth on color and sound bits and other subjects related to DV that I considered unimportant at first. thanks again.
Old April 4th, 2005, 03:59 AM   #11
Kyle, you are right about the 256 gray levels for the luma part in DV. This Y value is a decimated (into 8 bits/sample) version of weighted linear 3x8bits/sample RGB combinations which before decimation, results potentially in 16 million values where most of them (depending on the RGB weighting factors) would result in different gray levels. So, if one would create a B&W picture straight out of an RGB 8bit/sample structure the grayscale would have 16 mio shades. That's why I mentioned a "potential" number of gray shades of a 3x8bit RGB signal...
Old April 4th, 2005, 05:40 PM   #12
I found the book that I had once before. It's called "The Filmaker's Handbook (a comprehensive guide for the digital age)"
by Steven Ascher and Edward Pincus. It covers fairly broad, the issues and subjects about DV that I am now trying to learn about.
I will keep this book near my computer for now on and use it like a Dictionary when I get stuck. Thanks.
