NTSC to PAL via firewire at DVinfo.net
Open DV Discussion
Old October 1st, 2002, 10:20 PM   #1
Does anyone know what result you will get if you send info from an NTSC unit to a PAL unit via firewire? I am familiar with some of the differences , but will any data be transerred at all?
Red faced Scotsman
Francis Mcauslan is offline   Reply With Quote
Old October 1st, 2002, 11:50 PM   #2
ottotune
NTSC to PAL
Must admit that I have not tried to do that myself but I will bet that you end up with a nice black and white piece of tape.
I am over hear in Europe (PAL-land) and of course all of the American stuff that comes over here is NTSC... If you don't have a multi system that will switch between NTSC and PAL, you usually get a viewable picture but it is black and white.
Edward Tune is offline   Reply With Quote
Old October 2nd, 2002, 03:16 AM   #3
Francis, what do you mean by a unit? Camcorder?...VCR?... DV>analog convertor? Do you intend to record or just visualize(display)?
Andre De Clercq is offline   Reply With Quote
Old October 2nd, 2002, 07:41 AM   #4
No way without converter
As far as i know there are three big differences between DV PAL and NTSC
frame rate 50/60
number of lines 625/525
sampling scheme 4:2:0/4:1:1
PAL uses 12 tracks on tape for writing 1 frame, NTSC uses 10.
regards, Margus
Margus Kivilaan is offline   Reply With Quote
Old October 2nd, 2002, 04:00 PM   #5
Outer Circle
Canopus has a couple of converters.
Frank Granovski is offline   Reply
