Suggestions on Chroma key !!
hi, i wanted to know where to buy a chroma key background from and wat type of material. can i hang the green background in my rooms wall with the help of some double sided tape. which software would be best to remove the green background. following are my equipments.
Sony sr11 1000w halogen light kits x4 Rosco diffusion and tungsten to daylight filters 42" 5in1 light reflector Adobe premier, ultra should i be lighting the background directly with the halogen lights or make it diffused or converted to daylight color temperature ? |
light the subject as normal. Make sure shadows are not prominent on green screen. You may have to adjust your normal angles, or move the screen, or subject to achieve this. Then light the screen to make it bright and even - hopefully any shadows will be removed. Get rid of any creases. Add some backlight to the subject if you can to get some sharp edges onto the subject.
For software, I'd use Ultra every time! By comparison, the keying features in Premiere are quite basic. The other things in your list won't really be needed. You set colour balance in the same way you normally do. The green background is just a convenient colour that can be keyed, and is unlikely to be on the subject. The key to keying is having a good solid, bright background. Ultra can cope with small imperfections when you set the sample areas, and can manage to deal with shadows to a degree, but it's best to not have them in the first place if you can. The reflector might be handy if you need to bounce some light, but I suspect it won't really be very handy without some light sources shining in the right direction, and you won't have much spare to even do that. |
thanx paul, any suggestions from where to buy a chroma key background ?
B&H sells portable (pop-up) Botero backgrounds. Blue on one side, green on the other. I don't know how far they will ship it though.
botero green screen |
#5 |
well will those portable backgrounds be practical for shoots or should i go for a 10x12 or 10x20 etc muslin ones. wat about EEFX.COM - Chroma Key Green Screen Backdrops* (Foam Backed Fabric) these with some foam fabric, r they any good ?
#6 | |
I bought a 10x12 kit from EEFX.com a couple of years ago and I love it. It has provided the best and easiest keying experiences I've had so far. Fairly quick to set up, easy to get smooth lighting, and easy to key, all of which makes for a far more efficient workflow for both pre and post, IMO. -Jon
"Are we to go on record, sir, with our assertion that the 'pink hearts, yellow moons, orange stars, and green clovers' are, in point of fact', magically delicious?" - Walter Hollarhan before the House Subcommittee on Integrity in Advertising - May, 1974 |
#7 |
thanx jonathan, do u have any pics of ur chroma key setup, it would help me a lot to see the eefx background and also have an idea of its size.
#8 |
DVCreators.Net
I have the SR11 and have shot a few tests. One thing that's worth mentioning, well two, things. Make that three....
1) If you're shooting people tilt the camera sideways to get more resolution. Most people are tall and skinny :) 2) Consider the Blackmagic Intensity card. With it you can connect an HDMI cable and record Uncompressed or less compressed, right into Premiere. 3) Make sure to lock your exposure to keep the Auto mode from changing your settings. Here is the video I shot with the SR11 and the Intensity Pro. Sony HDR-SR11 Chromakeyed- uncompressed HDMI capture with Blackmagic Intensity Pro and Reflecmedia on Vimeo The Manfrotto head I use to tilt 90 degrees is the 410 |
#9 |
thank u so much Guy Cochran for the tips, i will definitely try the 1st and 3rd point. currently i am buying a chroma key background so i would ask u wat do u think about the eefx.com foam fabric green background ?
#10 |
DVCreators.Net
I've heard good things about the EEFX stuff. Depending on how good your keyer is, you may not need to worry so much about small wrinkles, only heavy ones which create shadows. Those are the challenge to key. Westcott has some decent folding backdrops too that you might want to look at http://www.fjwestcott.com/products/a...head=chromakey
And be sure to drop by the Lowel EDU site and check out their quick article on lighting green screen Lighting for Green Screen on Location |
#11 |
thanx man u r such a great help. i think i should go for the eefx green background as its also more cheap then the westcott sheets.
once i sticked a green paper chart on the wall directly towards the sun and my friend was about a foot away from it. i imported the video in adobe ultra and it came out really really good, i tried getting it keyed in premier and after effects but they weren't a match for adobe ultra. i think u should try adobe ultra if u haven't. |
#12 | |
-Jon
