burning to VHS straight from NLE, can it be done? at DVinfo.net
Open DV Discussion
Old November 4th, 2004, 05:03 AM   #1
Slash Rules!
My buddy claims you can record to a VHS tape by hooking up the cam to the computer, via firewire, and the the cam to the VHS, via RCA/S Video.
I have Vegas 4, if that matters. Anyone done this? The VCRs I have at my disposal are all rather cheap/old, and none have S-Video in/outs, though they do have RCA. Is there an extra component I'd need? Is it cheap?
Thanks.
Old November 4th, 2004, 05:10 AM   #2
RED Code Chef
Yes this will work as long as your camera supports digital in and
direct analog out (not all do this). It is the same system as using
the camera for a monitor out (to TV or broadcast monitor).
Rob Lohman, visuar@iname.com
Old November 4th, 2004, 12:55 PM   #3
Slash Rules!
Oh, well, then I forgot mention it's an XL1s. My bad.
Old November 4th, 2004, 01:00 PM   #4
The XL1 allow you to do this Josh. Simply plug it in your computer through firewire, then connect your VCR in the XL1 through RCA cables. Put your camera in vcr mode, ask vegas to preview on an external monitor, press record on your VCR, and play the vagas's timeline.
Jean-Philippe Archibald
http://www.jparchibald.com - http://www.vimeo.com/jparchib
Jean-Philippe Archibald is offline   Reply With Quote
Old November 4th, 2004, 01:01 PM   #5
Slash Rules!
Thanks! I'll try it.
Old November 4th, 2004, 03:57 PM   #6
Wasn't there some issues with getting the proper setup when doing this though. As in does the XL-1 video out have a signal at 7.5 IRE? Or do you have to go through a proc-amp?
J. Lamar King
DP - Fort Worth, Texas
J. Lamar King is offline   Reply With Quote
Old November 4th, 2004, 04:00 PM   #7
Slash Rules!
Sounds like a good question. I suppose you could raise the setup on one of the custom presets the approriate number of notches, if needed (I have no idea). Does anyone know how much to raise it to equal a 7.5 setup? Or do you need to raise it at all? I certainly don't have a proc amp.
Or is there something I can do in Vegas 4 to make it all come out correctly?
Old November 5th, 2004, 12:15 AM   #8
Does Vegas 4 have scopes?
View --> Video Scopes
Open up a filter that raises brightness. Raise the brightness until the vectorscope shows 7/8IRE. This is only for analog dubs where 7.5IRE setup isn't being added by your consumer equipment.
You can apply the effect to everything if you add the effect to where the video preview window is (make sure to enable it).
Old November 5th, 2004, 12:28 AM   #9
Slash Rules!
I think I had a whole thread devoted to setup and Vegas. I still don't get it. I'll be able to tell about this setup business if everything looks unnaturally dark on the VHS copy, right?
Old November 5th, 2004, 12:47 AM   #10
The thing to remember is anytime DV is going to hit analog you must ask yourself if set up is being applied somewhere. It could be applied through your camera, in your VTR or in your NLE. I honestly don't know if the XL-1 applies it or not, it might be switchable on the analog outputs like the DVX.
J. Lamar King
Old November 5th, 2004, 12:52 AM   #11
Slash Rules!
Definitely not switchable. . .I do know that.
Old November 8th, 2004, 06:41 PM   #12
Slash Rules!
Hey, guys, thanks! I tried it today, and it works!
It SEEMS the setup is fine, don't need to do anything in the NLE, but that's only according to the TV I watched it on as it was recording. . .could be wrong.
Another thing, and very important: DO NOT SIMPLY PLAY DIRECTLY FROM THE TIMELINE!
You won't get audio this way! With Vegas, you have to "print video to DV tape", without a tape in the camera, of course, record in the VHS machine, and then you'll get sound.
Old November 9th, 2004, 05:24 AM   #13
RED Code Chef
That's correct indeed Josh, thanks for pointing that out. Also if
you where to do a play from the timeline you might drop frames
here and there as well which a print to "tape" should not do.
Old November 9th, 2004, 05:26 AM   #14
Slash Rules!
Ah, and we learn something new every day. One day, it'll all be telepathy.
Old November 9th, 2004, 10:44 AM   #15
Although you do always waat to use "print to tape" to get the best finished results, you can send the audio out to your television from the timeline during the editing process. I don't have the program in front of me, but i think you need to go to the preferences section and there are audio options under output tab, or something like that.
Jesse Bekas is offline   Reply
