"stair stepping" at DVinfo.net
Open DV Discussion
Old August 24th, 2002, 03:02 AM   #1
Outer Circle
"stair stepping"
Stair stepping..., I know what it is, but I am unable to get it to see what it looks like. Any suggestions?
Old August 24th, 2002, 04:30 AM   #2
Warden
What camera are you using, Frank? If it has a sharpness control, try adjusting it. It can sometimes mask the edges. High contrast scenes are your best bet. I get them everytime I shoot a bird on a telephone wire, that is against a white sky or is somewhat back lit. On my product shots I get them on the edges of knives, forks and spoons. What are you using to view the footage? If I turn the sharpness, detail way down the edges will smooth out and you loose the stair stepping.
Jeff
Old August 24th, 2002, 05:24 AM   #3
Outer Circle
Thanks. I've tried the bird on the wire thing. I'll try it again, though. I have the DVL9500s and MX300s.
Don't get me wrong here. I'm trying to get stair stepping so that I can see what it looks like on my cams.
Old August 24th, 2002, 04:17 PM   #4
Hawaiian Shirt Mogul
stair stepping is seen on a line ( edge of object) that runs at a angle ( like a 45% angle ) in your frame .... if you move in ( zoom in with editing software) the line will NOT be straight - it will look like the side view of STAIRS ( the kind you walk up/down = stair stepping) ..also you can see it easy in a CIRCLE.
the bird on wire will work, just make sure you compose the frame so the wire is running at a 45% angle in the frame NOT a 180% horizontal or 90% vertical ....
Don Donatello is offline   Reply With Quote
Old August 24th, 2002, 09:50 PM   #5
Outer Circle
Thanks. I'll try this tomorrow, and play it back on my TV, via AV-out. The reason why I want to do this is so that I can avoid stair stepping when I do some serious shooting. So far, I've been lucky.
Old August 26th, 2002, 02:05 AM   #6
RED Code Chef
Frank, I think you'd be better off to watch the footage on a high
resolution monitor or on your NLE editing system. TV has a
tendency to more mask such issues. A monitor tends too be much
sharper (especially LCD screens, for example the one on my laptop)
Rob Lohman, visuar@iname.com
Old August 26th, 2002, 02:23 AM   #7
Outer Circle
Thanks. Today I did try to get this, but couldn't see any S.S. I'll have to pop the tapes in my buddy's portable Sony deck tomorrow.
