Ideal length of Firewire cable at DVinfo.net
Open DV Discussion
Old October 13th, 2004, 02:24 AM   #1
Hello
What should be the length of the firewire cable to capture from MicroMV and DV camcorder. Does longer cables result in loss of quality or it does't matter whatever the length is. I am planning to buy a 14' Belkin firewire cable.
Cheers
Nitin
Nitin Goyal is offline   Reply With Quote
Old October 13th, 2004, 06:01 AM   #2
Warden
No matter what type of cable, the rule is the shorter the better. In the case of FireWire longer cables are linked to dropped frames, increased error correction and I'm sure other issues as well.
Jeff Donald
Carpe Diem
Old October 14th, 2004, 11:56 AM   #3
will 6' be a better option
Old October 14th, 2004, 12:25 PM   #4
FirewireDirect has a nice answer to this question, which concurs with everything I've ever read on this subject:
Q: What is the maximum length a FireWire (A) cable can be?
A: The maximum cable length for connecting device to device with a 400Mbps cable is 4.5-meters (14.85ft). The Firewire specification calls for 10 meter (32ft) cables that may be used in conjunction with a repeater when it is necessary to extend FireWire cables over long distances. FirewireDirect does not offer these cables at this time because tests have shown them to be unreliable in some situations. We suggest using 4.5 meter cables and hubs when needing to extend to greater distances and don't recommend 10 meter cables (if you can find them) to our customers.
http://www.firewiredirect.com/firewi...s/cables.shtml
Imran Zaidi is offline   Reply With Quote
Old October 14th, 2004, 01:03 PM   #5
you got me confused
Old October 14th, 2004, 01:10 PM   #6
Warden
If you don't need the longer cable, a shorter cable is always best. In any case do not use a cable over 4.5 meters in length.
Jeff Donald
Carpe Diem
Old October 14th, 2004, 02:08 PM   #7
Right - what Jeff said.
