#31 |
Boyd,
Do you use only one tape and if so which one? |
#32 |
I've been using the Sony Premium tapes in the VX-2000 and PDX-10 for the past 3 years without problem. But you really should sample the opinions of others over at the tape forum.
#33 |
Boyd,
I got some Sony Premium tape today. The salesman suggested that I fast forward to the end of the tape and then rewind to the beginning to 'ensure' there was no slack in the tape. Have you ever heard of doing this? Is it necessary? He said something about if there was slack in the tape that it could damage your camera or something like that. Also, do you record only once on your tape or multiple times? |
#34 |
Doing that to the tape ensures even tension throughout, so you're less likely to get glitches/dropouts. Most people only rarely experience them, so I wouldn't waste time doing it. Also, 1 dropout does not affect quality much and is easily photoshopped out. Audio dropouts cannot be fixed but 1 should be ok.
2- I'd record once since recycling tapes increases the risk you'll overwrite an entire tape, which would be many times more disasterous than a dropout IMO. |
#35 |
Thanks Glenn. Sounds just right.
#36 |
<<<-- Originally posted by Steve Sawchuk : My personal opinion, having used only two of the three cameras mentioned, those being the GL2 and the Optura Xi, is that the difference is the picture quality. Not so much between the VX2100 and GL2, but the VX2100/GL2 versus the Optura. In other words, the Optura just doesn't look as good.
I played around with the GL2 at a local store, and then picked up the Optura Xi. I could immediately tell the difference between the two, and that was the quality. Now, I didn't get a chance to do any editing of the video or plug it into a TV to see it full-size, but it just seemed that the Xi was dull and the GL2 was broadcast-quality. Steve... I have tried out several Optura camcorders including the Xi. I think the user interface and construction are superb in all models. The still shots are ok to very bad. Autofocus is slow. The video is good. I decided not to get an Optrura Xi which, as you might know, was discontinued this past week. |
