Fast Background with Slow pan and tilt, How? at DVinfo.net
Open DV Discussion
Old August 14th, 2009, 06:25 PM   #1
I am trying to create this effect that Mr. Williams has done. Speed up the background, yes easy, but how is the slow pan and tilt done? I couldn't imagine trying to manually do it extremely slow, i think it would look a little jittery if done that way. This is really smooth. Here is the video as a reference. Any help in achieving this would be greatly appreciated.
Watch DVideography High Definition (HD) Wedding Video Samples From Philadelphia
Kevin Pineda is offline   Reply With Quote
Old August 14th, 2009, 07:59 PM   #2
Pan crop on the timeline using keyframes.
Jim Snow is offline   Reply With Quote
Old August 14th, 2009, 08:34 PM   #3
I've got a small DC electric motor that is geared very low, and I've rigged it so it fits between the plate & the camera. I can adjust it's speed somewhat, and has worked well in the past. Also rigged it to turn a broadcast zoom lens, looked good. Best of all, depending where I place the gear, I can hit record and leave for a while, come back when it's done it's 2 hours or whatever move.
Greg Paulson is offline   Reply With Quote
Old August 14th, 2009, 08:41 PM   #4
Don't let Greg's good humor discourage you Kevin. Do a search on "Event pan crop" and all will be revealed.
Old August 15th, 2009, 09:50 AM   #5
awesome thanks! lol
Old August 16th, 2009, 06:58 PM   #6
Agreed - Pan and crop in post is the way to go.
Art Fusion Night @ Dragon FX Kingsway - November 30, 2008 on Vimeo
I shot this on a Canon S5IS, which was at the time a top of the line point and shoot still camera. It was on full manual exposure and focus, and I used a tool called CHDK to enable me to set the camera to shoot at specific intervals. I imported the footage into Vegas at 6fps, and using the Event Pan/Crop tool, created the video you see here.
If I was to go back and shoot it again, I would definitely set it to a shorter interval. I think it was around 10 or 15 seconds between shots. I used a very slow shutter speed and ISO to maximize motion blur, to get a smoother look to the footage.
Good luck with your project!
Angus Findlay
http://www.findlayproductions.ca/
Angus Findlay is offline   Reply
