Making URLs on Posts Clickable?? at DVinfo.net
Open DV Discussion
Old June 1st, 2004, 05:03 AM   #1
I thought I knew how to make a URL clickable on
a post, as it was just discussed somewhere here recently. But, it didn't work the way I did it, so I need to be told again. It might be nice to have a Help section on the header of the main page, that gave instructions on things such as this. Another video forum has a check-box just above Submit, that activates an automatic parsing of all URLs in a message, to make them clickable.
Steve McDonald
Steve McDonald is offline   Reply With Quote
Old June 1st, 2004, 05:42 AM   #2
Warden
Hi Steve,
We do have a brief section on the codes, here, in the DV Info FAQ. The other forum uses different software, so that is not an option for us, but it would be nice if it did. Future versions of the software may contain such a feature, we'll just have to wait and see.
Basically it works like this:
{url=http://www.dvinfo.net/conf/}linked text{/url}
or to make an address clickable:
{url}http://www.dvinfo.net/conf/{/url}
Substitute {} for [] in the above examples. If I had used the lower case brackets the links would have been hot and you would not have been able to view them. Note, there are no spaces in the tags.
Jeff Donald
Carpe Diem
Old June 2nd, 2004, 04:03 AM   #3
I always use the lower case brackets, with no problems
so far.
Dave Largent is offline   Reply With Quote
Old June 2nd, 2004, 04:44 AM   #4
Warden
You must use lower case brackets for the links to work. If I had used lower case brackets, the links would have worked and Steve would not have been able to see the code to know how it works.
Jeff Donald
Carpe Diem
