How is it done? at DVinfo.net
Open DV Discussion
Old July 12th, 2002, 08:22 AM   #1
How is it done?
I have seen recently the effect of one subject normally a person in full colour while the rest of the picture is in black and white, how is this done?
Or that one specific colour shows up i.e. blue while the rest of the colours are black and white.
Any advise on how to create this type of effect would be appreciated.
I’ll be using Premiere 6 and Photoshop
Ed Smith
Ed Smith is offline   Reply With Quote
Old July 12th, 2002, 08:45 AM   #2
RED Code Chef
This is either done by filming the items seperately so that you can
combine then afterwarts with different colors (or B/W etc.). Or it
is filmed in as one picture and they grayscale everything except
a certain part which is selected each frame. Rent the DVD disc
of Pleasantville... that disc has making off that shows you their
process... They also warn that if you shoot in color you should
have a monitor on set that shows the image in B/W (dial out
the chroma) so that you know if your seeing what you should.
Certain different colors are the same in B/W!!!
Rob Lohman, visuar@iname.com
Old July 12th, 2002, 10:44 AM   #3
Rotoscoping is also used when there are not two different plates for the B&W and color footage. This is just manually separating an object from the rest of the clip. On the Commotion website(www.commotionpro.com) this exact effect is explained (http://www.commotionpro.com/products/commotion/why/rotoscoping.html). Enjoy.
Daniel M. Carrico
www.danielcarrico.com
daniel1113[at]comcast[dot]net
"For those who believe, no explanation is necessary. For those who do not, none will suffice." - Joseph Dunninger (Mentalist/Magician)
Daniel Carrico is offline   Reply
