Camera not able to record timecode at DVinfo.net
Open DV Discussion
Old May 7th, 2004, 02:57 AM   #1
recently i posted a topic on minidv tape's timecode problem. please first check the link then continue...
http://www.dvinfo.net/conf/showthread.php?s=&threadid=25414
now i just got a new cam. last night and i used it to check my old tapes. (to make it clear, please note 1. the old cam = canon optura pi, new cam = canon zr 60; 2. the old tapes were shot with JVC, new tapes are shot with pi and there are two batches, first shot before the timecode problem, second shot after the time code problem.)
ok here it is. i checked the old tapes with zr 60 and the timecodes are fine. but the new tapes i shot with pi after the timecode problem are messed up.
so my question this time is: how does the camera records timecode? and if the camera can't read the timecode correctly, does that mean the camera can't produce correct timecode either? if there's something wrong with the camera,
is it repair able?
if footage shot with a camera that cannot record timecode, so there's no timecode on the footage, how can i capture?
Charlie Wu
Charlie Wu is offline   Reply With Quote
Old May 7th, 2004, 08:10 AM   #2
First off you can repair the timecode. Just copy the tape from cam-to-cam and you should get a new timecode.
Not all NLEs need timecodes for editing. Different packages have different means of doing this. Generally, you can just do a capture without setting in/out points by manually.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply
