Only ONE file on my video drive and it's totaly fragmented?
Captured a single small clip (totaling 1gig) on my dedicated video hardrive. Just for the heck of it I ran defrag on that disc and the graph is showing the block as all red, or ALL fragmented. Does anyone know why capturing a single video file on a practically empty hardrive would report the file to be completly fragmented? Oddly enough defrag didn't state I "needed" to defrag.
Yes, if the drive was just emptied through deletion and not through formatting, then sure, the OS will drop any new files into whatever slots it finds that don't interfere with slots that are being saved for recently deleted files, etc.
Whenever doing large scale deletion on a drive it's often a good idea to do a defrag right after, and before continuing use of the drive. Just keeps things running smoothly. If, however, Glen, it was indeed a newly formatted drive and it still did that, then you got me - no idea why that would happen in that case. |
No oddly enough it's the second file I ever saved on it. I have 3 drives, 1 OS/Programs, 1 for media and images, and 1 for video. The video drive is completly empty accept an AVI from a recent commercial I finished. I captured some new footage, roughly 10 minutes worth. Another odd note is the from the left to right I saw a blue block and a larger red block adjacent to it. Once I defragged which took an inordinate amount of time judging from the amount of data on the drive it moved the large red (fragmented block) to the right leaving a large gap between the original blue block and the previously fragmented block. ????
Also notable when I was defragging it states the file it's currently moving (usually too fast to read...but slow enough if it's large files) and it stated "PD-170 TEST.avi (audio)". The avi was indeed named PD-170 Test but why the "audio" in parentheses? It was like it was ONLY moving the audio in the avi file- is that possible- avis are linked- both video and audio...right? I only figured I'd mention this because it spent a good 5+ minutes just on this file with the hardrive thrashing. |
#5 |
You might want to confirm the physical disk isn't degrading.
I'd copy the file off the disk, do a full re-format, and see what happens when you copy it back. If it keeps thrashing and splitting up files like you described, there might be some serious bad sectors on the disk. * What OS and file system are you using with the hard disk? |
#6 |
OS- Windows XP home. File system- NTFS
It's a brand new Maxtor 120gig SATA Diamond Max Plus 9. I have 3 of them- they are great. It's not "spliting" up the files- at least according to the graph it isn't it is all one contiguoius chunk yet it's Red like the content of the chunk isn't all the same file. Usually when I run defrag on my OS drive I have gaps AND red areas. This had no gaps just a big chunch on the left of the graph which was 2/3rds red. |
#8 |
No prob- disc degregration could cause similar oddities in performance. I'll keep a close eye on the drive in the future to see if it continues to fragment new files to a freshly defragged drive.
#9 |
I have seen instances where the NLE creates a mess while capturing from FireWire. Not sure of the root case in the NLE though.
#10 |
RED Code Chef
The (audio) file should definitely be a different file. It could be
a peak file from your NLE. If you are not showing hidden files then you might perhaps not see it. Which capture / NLE software did you use? Or any other software on the file? It's a bit weird it is fragmented indeed...
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#11 |
I'm sorry Rob, I should have updated this thread as soon as I discovered. I found out the name of the clip was, indeed, "PD-170 first test (audio).avi". I didn't realize I put the "audio" text in the name. So apparently it was moving the entire AVI.
Now the only thing I can think of- I had a couple small files on the drive- is it a possibility that if there was a gap between them for any reason once I started capturing the long file it first filled the gap and the rest of it got relocated to the adjacent side of where the last file ended? In turn it would appear as a large red block beings it's a 1.7gig file. Better yet- if a file is fragmented at one point- as in only in two sections will the entire file show up as red? |
#12 |
RED Code Chef
I believe the entire file will be red even if there is one little breakup
in the file. Keep in mind, as others have pointed out, that by default when you delete a file in Windows it is moved to the recycle bin (unless the file is larger than your recycle space) and thus the sectors the file is occupying are NOT released. So a couple of files on your disk could definitely have such an effect. If you hold down the SHIFT key while deleting the file be deleted directly instead of moved to the recycle bin. Ofcourse you can also clear the bin so that the files are permenantly removed. That should insure an unfragmented file.
