Program Dropping frames when capturing at DVinfo.net
Open DV Discussion
Old June 10th, 2009, 07:07 PM   #1
Sometimes when I am capturing video the program drops frames. This causes the video to appear jumpy and looks BAD. Is this a software issue, a camera issue, or a tape issue?
Before you ask, I am using a Canon GL-2 with Panasonic tapes and Pinnacle Studio 12.
Thanks for any help you can offer!
Chris Mier is offline   Reply With Quote
Old June 10th, 2009, 07:32 PM   #2
I'm guessing you're capturing via firewire? If so, it's the software dropping the frames.
Generic advice is to make sure any unneccessary programs aren't running to give the capture application maximum CPU availability.
Gene Gajewski is offline   Reply With Quote
Old June 10th, 2009, 08:05 PM   #3
I second that. Restart the computer, make sure nothing is running except Pinnacle, and don't use the computer until the importing is finished. Also try turning off the import preview. That helps sometimes.
Greg
Greg Donovan is offline   Reply With Quote
Old June 10th, 2009, 08:30 PM   #4
Thanks, will try that.
Should I use soomething other than firewire?
Old June 10th, 2009, 08:39 PM   #5
No, you need to use firewire.
Greg
Old June 10th, 2009, 11:37 PM   #6
While certain programs like antivirus can cause this, sometimes it is the Firewire cable. I bought a cheap one in the beginning and had these dropouts. Unfortunately, not all Firewire cables are equal and getting a good one can help avoid this.
Ken Campbell is offline   Reply With Quote
Old June 12th, 2009, 07:53 AM   #7
Can I use a Portable Hard drive?
I am shooting with 2 GL-2's, one on a tripod and one on a glidecam 2000, and was wondering if I could use a portable harddrive while taping? Would this help with the frame dropping issue?
Old June 12th, 2009, 08:09 AM   #8
WinDV (freeware) is one of the few DV capture apps that uses a memory buffer, which can help prevent dropped frames:
WinDV
Robert M Wright is offline   Reply With Quote
Old June 12th, 2009, 11:02 AM   #9
If your editing software can import the file then do it - save time (don't need to capture) and no more drop frame.
Tuy Le is offline   Reply With Quote
Old June 12th, 2009, 12:52 PM   #10
Follow-up to prev post
Will the camera also record to tape as well?
Old June 12th, 2009, 06:54 PM   #11
Getting something like a FireStore is a fairly expensive way to deal with the issue of your computer dropping frames while capturing, and really doesn't resolve whatever the issue is with your computer in the first place (a bit like buying bottled water because your faucet doesn't work). Likely causes include a badly fragmented hard drive and excessive bloatware running in the background. Whatever is causing the dropped frames, the issue(s) should be put to rest, regardless of doing anything else.
