Is adding gain on camera any different from adding brightness in post? at DVinfo.net
Open DV Discussion
Old May 10th, 2009, 02:36 AM   #1
I'm using a hv30.
If I set a shutter speed or f stop, then go to exposure and make the image brighter (purely gain and not the iris opening i'm guessing), is that any different from just adding brightness or gamma in post?
Gary Douglas is offline   Reply With Quote
Old May 10th, 2009, 04:40 AM   #2
In post you can only extract what's there. If the camera picked up nothing, that's what you'll extract.
Dean Sensui
Old May 10th, 2009, 06:19 AM   #3
Boosting brightness in post is akin to boosting gain on the camera. Boosting brightness in post is amplifying the signal recorded by the camera. Boosting gain in the camera is amplifying the signal from the sensor. A difference though, is that in post, you are boosting a signal recorded at 8 bits (usually), whereas using gain in-camera the DSP is usually working with 10 or more bits.
Robert M Wright is offline   Reply With Quote
Old May 10th, 2009, 07:51 AM   #4
Dean is right about "you can only extract what's there". The additional caveat is that once the noise generally associated with "gain up" is added, it is difficult to impossible to remove completely. My PERSONAL position is to use as little gain as possible to get as much exposure as I can in field without adding noticeable noise and then using a 3 way colour corrector (NOT brightness) in post to reset my black, white and gamma (midpoint, sort of...) points.
Old May 10th, 2009, 09:38 AM   #5
Gain doesn't really add noise. It simply amplifies what noise is already there (along with signal) in the first place, whether it is done in-camera or by doing the equivalent in post.
Old May 10th, 2009, 09:47 AM   #6
I might be wrong regarding the new breed of camera sensors, but what I learned in my TV/Film classes was that gain is increased by 'flashing' the sensor with a small amount of light to bring up the minimum sensitivity levels. A sensors 'bucket' won't move a charge unless it detects one...by putting a small amount of light in that 'bucket', it doesn't take as much to have it register and moved along the pipeline. The grain results because these photosites (buckets, as I call them), that normally wouldn't fire, are now firing.
This isn't the same process as adding brightness in post, which accounts for the difference in the resulting image (post brightening tends to wash out an image).
Oren Arieli is offline   Reply With Quote
Old May 10th, 2009, 12:49 PM   #7
Actually, gain DOES add noise. Any amplification of an electronic signal past unity gain adds noise.
Old May 10th, 2009, 08:41 PM   #8
I should add a bit to clarify my statement: It's ok to brighten it up a -little- in post. But not a whole lot.
As for during production, shutter speed can be adjusted if you want to keep a particular f-stop. But extending the exposure time also increases the accumulation of noise. As usual, anything extreme can have extreme results.
Best way to find out is to test it and see.
Dean Sensui
Old May 11th, 2009, 06:29 AM   #9
I would say that its better to adjust the brightens in post, because if your not satisfied whit the results from the gained camera, you can do nothing. But in post, you just have to remake, if you not happy the first time.
John S. Cooper is offline   Reply With Quote
Old May 11th, 2009, 09:25 AM   #10
I'd have to disagree here. I've used HV20s, HG10s and HG20s. I always shoot in cinemode, as that adds the least gain.
I've got to say that adding gain in post is usually less noisy than adding gain in the camera, though I don't know why that is.
Equip: Panny GH1, Canon HG20, Juicedlink, AT897, Sennh. EW/GW100, Zoom H2, Vegas 8.1
Brian Boyko is offline   Reply With Quote
Old May 11th, 2009, 06:30 PM   #11
Well, ya can't make a silk purse out of a sow's ear (and remember, avoid cliches like the plague).
My theory is to add as little gain as possible in camera--enough to get the image. The nice thing about post is that you can control it better. You are probably rushed and need to concentrate on different things during the shoot but back home, you can take your time and balance noise vs brightness level.
Andy Tejral
Railroad Videographer
Andy Tejral is offline   Reply
