24P vs 24F? at DVinfo.net
Open DV Discussion
Old May 7th, 2009, 12:59 AM   #1
24P vs 24F?
Hey,
I'm about 10 hours into my documentary using the Z7u (24p/1080i). I'd like to switch to a XH A1 I can get for free. I'm shooting mostly outdoors with just a few indoor interviews. I know there might a difference in color, but what about 24p vs 24f?
Patrick Marte is offline   Reply With Quote
Old May 7th, 2009, 03:59 AM   #2
There's no practical difference between the two and there should be no technical reason why it wouldn't integrate with your Sony's footage.
Because the XH A1 uses an interlaced sensor, Canon elected not to call their 24 frame mode 24f.
Old May 7th, 2009, 04:09 AM   #3
Tripp, I think you mean "elected to call" ;).
One thing that you should be aware of is that 24F is kind of the redheaded step child of HDV when it comes to NLE support.
FCP and Vegas seem to be able to capture it fine. But Premiere and Avid seem to barf on the timecode, so if your editing on one of those you will probably have to capture w/o timecode and have the NLE assign a new timecode.
The XH-A1 is also very tweakable in terms of color and other settings. So if you spend the time, you may be able to get very close to the Sony's footage. Or create a look that you like very much. Set to factory defaults, it the colors look a little flat, but that can be tweaked away.
Good luck, the camera takes truly amazing pictures :).
Avid Media Composer 3.1.3. Boris Red and Continuum Complete. Vegas 8.0c. TMPGEnc Xpress Pro 4.0
Old May 7th, 2009, 04:35 AM   #4
Peter... Yeah, you're right. Only 1 cup of coffee thus far.
BTW... I have no problem with 24f timecode in Adobe CS3 and I use 24f a lot.
Old May 7th, 2009, 05:03 PM   #5
Guys,
A million thanks! I'm getting ready to go out again and I just don't have the money to get the Z7u, so I needed some good news.
What I'll do is shoot some test footage and tweak the Canon. And I'm cutting on fcp, so I shouldn't have tc problems.
Old May 11th, 2009, 06:31 AM   #6
It shouldn't be any difference between 24p and 24f
John S. Cooper is offline   Reply With Quote
Old May 14th, 2009, 08:48 PM   #7
There is no difference... 24F is indeed native 24p progressive scan.
Old May 22nd, 2009, 01:52 PM   #8
As I remember there is a difference in the way Sony records 24P compared to the way Canon records 24F. Canon was recording 24 Frames to tape while Sony was using 24 frames within a 60i datastream. Canon did this so they wouldn't waste data on duplicate frames. Older Sony decks could not play the Canon 24F 1080 footage while newer ones can. Canon started following the Sony Protocol with some cameras which recorded 24P but the XA and XH series were not among them. The little Canon camcorders could play back either form but didn't record in both forms.
In the end the result may be the same but the path from recording into computer and what settings you use may be a little more complex depending on the deck/camera/computer you use to edit and digitize.
Daniel Epstein is offline   Reply
