#16 | |
Checking if I read this correctly, comment within.
#17 |
Since quotes cannot be quoted here, I'll re-lay this out.
** Do you mean PC based tools which reduce the amount of human time required? The capture from dv-tape could only move as fast as the camera output** >>> No, not from DV tape. I was referring to ripping video from a DVD. Sorry if I misunderstood your reply. **Do you mean a data DVD burner w direct input from a dv cam to do that is available (as I originally wanted), or a dedicated "DVD recorder" device? I can't find the former, so am looking at the latter. >>> No, not a data DVD burner. There are, however, several DVD recorders that will. Think of these as VCRs but with DVD drives instead of tape transports. The theory is very much the same. *Visible quality loss - good to know. Sounds like I'll need to keep some portion of the physical tapes.* >>> For most of us without LTO tape, keeping the source tapes is the best way to archive footage. |
#18 |
I am almost certain that thee is a windows program that will let you record video from tape in your camera direct to dvd writer in your computer but cannot remember where I saw it, might be worth having a search round sorry I can't remember but if I do I will certainly let you know.
Alan |
