Sony DCR-TVR33 Low sound at DVinfo.net
Open DV Discussion
Old December 27th, 2003, 04:37 PM   #1
Hi
I just bought a Sony DCR0TVR33 DV cam. after playing around with it for a while. I noticed that the audio it records is very low.
You would have to talk right into the mic to get anything.
I have read throught the manual and found no way of turning up the mic gain. Is this normal for this camera?
Peter Le is offline   Reply With Quote
Old December 29th, 2003, 02:42 PM   #2
RED Code Chef
Anyone?
Rob Lohman, visuar@iname.com
Old December 30th, 2003, 05:02 PM   #3
Sony cameras have an auto-gain control circuit that is supposed to raise the volume of the mic if it's really quiet (and vice versa). It sometimes does a reasonable job, but when it doesn't it's really annoying. AFAIK Sony consumer cameras do not have manual audio control. Also, Sony cameras tend to record all the way up to 0dB in loud situations (0dB=the loudest you can get).
Your camera might be busted.
You're using the on-board microphone right? (on-board mics tend to suck though... :/ )
Old December 30th, 2003, 06:08 PM   #4
Outer Circle
I agree. If that's the case you cam is most likely "busted."
Frank Granovski is offline   Reply
