Shooting a Solar eclipse at DVinfo.net
Open DV Discussion
Old May 3rd, 2002, 01:30 PM   #1
Hi,
has anyone shot a solar eclipse from start to finish. If so how did you do it ? What filters did you need to use? What precautions did you take?
Regards
Andrew
PAL XL-1, DV Raptor, Premiere
TOTAL AMATEUR - DOING IT FOR THE FUN
Andrew Leigh is offline   Reply With Quote
Old May 3rd, 2002, 10:00 PM   #2
I once shot one in 35mm. I went to a welding shop and got welding filters, the size that will cover the entire front of your lens (usually used in masks). Get one for yourself so you can watch the event. These solar events happen so infrequently that it's a long time inbetween takes.
Good Luck
Bruce
Bruce Moore is offline   Reply With Quote
Old May 3rd, 2002, 11:59 PM   #3
Hi Bruce,
thanks for the tip.
Cheers
Andrew
PS: Will contact you later this weekend, off to shoot an aerobatic display.
