Letus Extreme or JVC HD110U?
I know it seems a little awkward questions, but I have a good reason for it.
I have about $3000 budget to add extras to my XH-A1. Letus Extreme has been my thoughts for shallow DOF for interviews and maybe weddings (details and whatnot). Then when I visited B&H this afternoon, I saw JVC HD110U for $2999.99. If stock lens on HD100U is good enough for me to have shallow DOF, why not? I would not have to bother with rails and attaching/detaching lens & adopter from cameras and whatnot. Then again, how smooth would workflow be with HD110U for the editing? For the price, I could get a brand new HD110U with money that I could get Letus extreme plus lens. HD110U's DOF would not even close to using Letus, but would it still a lot better than XH-A1? I am keeping all the extra stuff for HD110U to a minimum if that's where I am heading. Any thoughts? I would greatly appreciate your opinions on this. JJ |
#2 | |
Workflow with JVC's depends greatly on what edit software you use - SPECIFICALLY what version of any given software. And this is coming from someone who is VERY happy to own 2 HD200U's.
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
Thanks, Shaun. Since their chip size is same, I thought wider aperture of JVC lens would make some difference, but I don't think that's the case here...
JJ |
As part of a focal distance/focal length/aperture combo, I'm sure it will make a BIT of a difference, but nothing massive. I would suggest that imager size is probably the biggest single factor in DOF.
#5 | |
I bought a Brevis35 to use with my HD100 because the DOF was virtually the same as every other 1/3" miniDV, HDV camera out there. Stick with your XH and get the adapter if you want shallow DOF.
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
#6 |
In addition to the fact that the DOF is the same as with any 1/3" camcorder, the Fujinon stock lens on the JVC GY-type camcorders has a terrible "wide angle" of 5.5mm - you'd really have to consider a wider lens, the 5.5mm is really not fun to work with as your widest focal length.
Other than that I think the GY-types are the best to work with 1/3" camcorders because of their real manual lenses and the shoulder mount form. |
