Wireless Video Transmission.. suggestions? at DVinfo.net
Open DV Discussion
Old December 4th, 2003, 08:01 AM   #1
Hi. My background is primarily in motorsports action sports video. I am now in a situation where some video work i did for a company has led to needing to propose potential costs to shoot live video for [website] broadcast.
The video in question would be shot by 3 XL1S's.. and i'm trying to look into wireless video broadcast solutions, but not having much luck (aside from finding security type related products). Budget isn't as much of an issue as finding the right solution.
Need to broadcast video from 3 different [camera] sources, to a receiver (or multiple receivers if need be), across a distance of 100 - 3000 feet, not necessarily line of sight either. I know.. tall order. And a bit out of my expertise.
Wondering if any of the folks here have suggestions for me? I attempted to use the search feature.. but it doesn't seem to like booleans..
Adam Burtle is offline   Reply With Quote
Old December 4th, 2003, 09:11 AM   #2
For web broadcast a really good program is Live Channel Pro by Channel Storm. http://www.channelstorm.com/Product.html
I have no idea about wireless transmission.
Old December 4th, 2003, 10:16 AM   #3
For Wireless Transmission, first try calling up a Film Rental/Supply company. I don't know what area you live in, but here in Toronto, the film industry is huge, so there are a few companies which supply the ongoing productions within the city. These companies would be able to suggest something to you, since many film productions use wireless video transmission for monitoring.
I did find this product while doing a search...the range is up to 3000 feet.
http://www.rf-video.com/home/steadicam.asp
Good luck
Tony Singh is offline   Reply With Quote
Old December 4th, 2003, 10:37 AM   #4
Moderator
You'll probably need to budget in for an extra person - you will inevitably run into the need for someone to "go do this" or "go do that" during the event - as your needs sound somewhat complex. You want to make sure that you make a good impression to your client and that you don't end up looking like the Three Stooges in front of your client.
You also should consult with and pay for the services from a professional who specializes in this - if you are charging your client for this, you want to get it right the first time - at all costs, or they will not ask you back.
Give Wolf Seeberg a call at Wolf Seeberg Video (310) 822-4973, Fax: (310) 305-8918, "wolfvid@comcast.net"
Wolf knows wireless video. Wolf is one of the people that the rental houses defer to for wireless video. Wolf is a busy guy, but also very friendly and knowledgeable!
Also try Aerial Video Systems in Burbank at 818-954-8842. http://www.aerialvideo.com
Please do let us know how you make out and if you have any other questions, ok?
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old December 4th, 2003, 02:33 PM   #5
Try here:
Rafal Krolik is offline   Reply With Quote
Old December 4th, 2003, 08:29 PM   #6
LAIRD wireless transmitter
This is new from LAIRD. The only thing is that they don't provide a receiver. Any monitor with a tuner can see the signal, but that means if you want to go portable on location, you have to rent or buy a small portable LCD or CRT system with a turner to receive the video. It never ends! I spoke with them about offering a matching reciever because a lot of us have already invested in these portable LCDs without tuners. They said thanks for the input and would consider it.
http://www.lairdtelemedia.com/produc...dcam.html#WAVE
James Emory is offline   Reply With Quote
Old December 4th, 2003, 08:35 PM   #7
Microwave Solutions
Check out this site. Once there, put wireless video in the search field. I think you're going to need microwave for your application. These guys have it and you'll pay for it!
www.markertek.com
Old December 5th, 2003, 09:24 AM   #8
I hope somebody will post some SUCCESS STORIES related to this topic. I did a lot of research on this over the summer and finally settled in on what I thought was going to be a pretty good system... under $300... anyway, the dropouts and static make my system almost unusable! The unit I bought is a heavy duty design with beautiful aluminum cases... but looks/specs were deceiving.
If I were you I'd try the Laird if you can handle that size... Markertek's units are similar to the one I bought... but pretty much cheaper price and appearance.
Good luck and let us know what happens!
Matt Gettemeier is offline   Reply With Quote
Old December 5th, 2003, 02:26 PM   #9
Adam,
This may be a bit extreme but could work well for you:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2967834681&category=3319
Rob Wilson is offline   Reply With Quote
Old December 5th, 2003, 06:40 PM   #10
Moderator
Adam,
You are best off hiring the services of someone like Wolf Seeberg to insure that your first adventure with wireless video proves to be a professional experience for all concerned, including your client.
It costs a good deal of money to purchase a system that will handle your needs. A $500 solution will not suffice if you want flawless video.
I really think, based upon your requirements, that you will need something of the level of a Modulus 3000 wireless video txmitter system - starting price on that puppy is $2000. That is just for the transmitter. You want a system that will not squash the bandwidth of your video signal.
If you are unexperienced with wireless video, do yourself a favor and hire a specialist - not expensive at all when you consider that it will be done properly and transparently. Your client is not going to want to hear any excuses.
Let us know how you make out,
- don
Old December 6th, 2003, 08:23 PM   #11
Wireless
The wireless solutions at Markertek are not necessarily their brand. They carry several different brands of the 3-5 thousand + dollar range systems. One of which is said to be used by Fox Sports Net. Now if it's working for them, you might want to check it out. Bexel, www.bexel.com , is a worldwide rental company that has a high end system called Dynapix. I agree with Don. It wouldn't hurt to have a knowledgeable person to configure the setup for you, at least for the first time.
Old December 6th, 2003, 09:24 PM   #12
Moderator
My good friends from Bexel in Burbank are the ones who suggested contacting Wolf Seeberg from the get go. http://www.bexel.com/networkburbank.htm As I stated before, most rental houses who cater to high end wireless video applications defer to Wolf, as he is a specialist.
Your basic starting point solution to consider would be a Modulus system.
- don
Old December 8th, 2003, 06:00 PM   #13
Thanks, everyone, for your suggestions.. especially Don. I had a chance to speak with Wolf (at your suggestion) on this matter, as well as doing a lot more reading on the net. Sorry it took me a few days to pop back in and reply, i've been rather busy lately...
Wolf has a microwave setup that works well for roving video, and we'll probably go with that in the end, assuming the proposal is approved. My previous understanding was that an FCC license was needed for microwave transmission, so it was good that i was able to speak with him, and he told me it wasn't needed (at least not with his setup).
As far as budgetting in an "extra person" .. that had already occured to us, don.. i can't even imagine the hassles that we will encounter shooting this. Not to mention, this is video of live car racing, in a form of racing known for throwing tons of debris haha.. so we're attempting to forsee not only the need for an additional "gopher" to get supplies and help out, but budget in potential equipment failure from debris and whatnot.
Old February 9th, 2004, 02:57 PM   #14
It's going to be expensive. Most of those setups are for transmitting video to a videotap or a monitor for the director. You won't be able to really rely on most of those systems for a steady image for recording from. High movement, other devices broadcasting, and even the signal from the device if unshielded itself could provide massive interferrence to recording it from a distance.
THose devices are great though if you just need to monitor whats going on. Be prepared to pay a hefty sum for a usable system. your reciever system is going to large and expensive.
Director: http://www.mediathreat.com
John Threat is offline   Reply With Quote
Old February 9th, 2004, 03:34 PM   #15
Just chiming on this, I agree with the suggestion that you need Microwave. Even the best of the TV band transmitters like the Modulus will cause breakup and are only meant for monitoring purposes as John Threat mentioned. I've owned a Modulus for years and while it is a lovely piece of gear (and MUCH smaller than the Laird, unless the picture on their website is not to scale), it is prone to interference like all such systems.
Charles Papert
www.charlespapert.com
Charles Papert is offline   Reply
