Do I need a CCU ? at DVinfo.net
Open DV Discussion
Old November 24th, 2003, 04:13 PM   #1
Do I need a CCU ?
I need to get either RGB or Y/C from the Sony CCZ 26 pin connector. Can I do this with a special cable (if so what cable?) OR do I need to go via a CCU.
In either case what cables do I need ?
I wish to record RGB from a DXC 537/CA 537 direct to a DVD RAM recorder which accepts either RGB or Y/C
Help Appreciated
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old November 25th, 2003, 03:45 AM   #2
RED Code Chef
John, you indicated that you solved the problem. Can you
describe us what you did and perhaps point to a site containing
the solution? It might be interesting to have this on record for
other people. Thanks.
Rob Lohman, visuar@iname.com
Old November 25th, 2003, 08:14 AM   #3
the information can be found in documents at the site referred to by
http://www.dvinfo.net/conf/showthrea...threadid=17531
John Jay
