why "Y" (and not "L") for luminance? at DVinfo.net
Open DV Discussion
Old November 19th, 2003, 01:34 PM   #1
Does anyone know why the luminance component is marked "Y" instead of "L"?
Stu Minnis is offline   Reply With Quote
Old November 19th, 2003, 04:15 PM   #2
Many decades ago the C.I.E. defined a trichromatic color concept (color space), underlaying all color TV systems. They proposed a 3-dimensional space (X,Y,Z) which was transformed in such a way that only the Y axis represented the "luminance" of any color belonging to that space. The "Y" in color TV is being derived from this representation but is being gamma pre-corrected so that its numerical value(IRE) is no longer equal to the "luminance" seen on a TV screen.
Andre De Clercq is offline   Reply With Quote
Old November 24th, 2003, 08:51 AM   #3
RED Code Chef
Interesting... I didn't know that. Thanks!
Rob Lohman, visuar@iname.com
Old November 24th, 2003, 08:36 PM   #4
Andre,
do you know why, on SONY gear,
that
Y is Green or Luminance
R-Y is Red or Chroma
B-Y is Blue
just curious
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old November 25th, 2003, 04:39 AM   #5
Allmost all manufacturers apply configurable connections for analog signal in/output. There is no "technical" reason for specific allocations. Only minimizing the number of connectors and output/input amplifiers (and cost!) is the point. In general if cinch connectors are involved they can be set for RGB or Y, R-Y, B-Y or composite, or (if not taken by a Y/C hosiden connector)also as Y/C. Also SCART connectors often have configurable pins. The Y signal (in Y/C or Y, R-Y,B-Y setting) and the green channel (in RGB) and the composite signal are mostly taken on the same connector. Chroma (in Y/C connections) and red (in RGB) and R-Y (in Y, R-Y, B-Y setting ) are also assigned to the same connector. Blue (in RGB) and B-Y also shear the same connector
Old November 25th, 2003, 06:57 AM   #6
I could be mistaken, but I think John is asking why Sony uses the Y/R-Y/B-Y designations, as opposed to the more often seen Y/Pr/Pb designations. Are they the same thing? Is this just a bunch of propietary naming nonsense (which Sony seems to be fond of)?
Also, Andre, respectfully, would you mind elaborating on your two previous points with slightly less technical language. There's a lot of stuff in there that flies over the head of those of us with no engineering background.
Thanks.
Old November 25th, 2003, 10:33 AM   #7
Sony's designation is actually easier to understand.
Y=Luminance
R-Y=Red - Luminance
B-Y=Blue - Luminance
Makes it easier for the average consumer.
Tony Singh is offline   Reply With Quote
Old November 25th, 2003, 03:24 PM   #8
Stu, it's a bit a long story..., could you tell me what exactly you wanted to know?
