Safe to mix Fuji tapes with Panasonic? at DVinfo.net
Open DV Discussion
Old September 28th, 2003, 02:44 PM   #1
I think the answer is yes, but I just want to reconfirm:
I've always used Panasonic MiniDV tapes in my gear, but I've come into some Fujifilm "DVCassete" tapes. If I recall correctly, Fuji is the manufacturer for the Panasonic tape anyway (or is it vice versa?), and so mixing Fuji with Panasonic won't gunk up the heads of my camera/deck.
Is that right?
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old September 28th, 2003, 03:32 PM   #2
Outer Circle
Why would you presume that just because Fuji may manufacture tape for Panasonic, these tapes are the same?
Old September 28th, 2003, 03:51 PM   #3
Which Panasonic tape? It all depends is the answer, and there seems to be a lot of confusion over which ones are the same, dry/wet, etc. That's why I don't mess around, I use only the same brand and type, because that seems to be the only way to be 100% sure.
Even mixing tape types among the same manufacturer can cause problems, for example Panasonic MQs and PQs.
Sean R Allen is offline   Reply With Quote
Old September 28th, 2003, 04:38 PM   #4
The Panasonics I've always used are AY-DVM60EJ ME tapes.
The new Fujis are DVM60A ME tapes.
All the best,
Robert K S
Old September 28th, 2003, 07:09 PM   #5
Outer Circle
Robert. I don't know if mixing these will cause gumming/drop-outs. I never mix brands and types because I have seen problems first hand with doing this when I shot for people who have hired me with their cams and tapes. Also, most of the pros I know mostly use Fuji, but some use Pana, some use Sony. The ones that use Fuji say they've had the least amount of drop-outs with this tape. Another thing I've noticed over the years from cam boards is that people are always asking for help with describing a certain problem. Problem: gummed heads (they usually don't know this and just describe what they see---blocky footage etc); and when I ask what tape they are using, most of the time they reply with that they mixing tapes (with a list, of course). Sometimes people get gumming by just using a "cheap brand" of tape, like I did with JVC miniDV a number of years ago.
