Glue for Foam ? at DVinfo.net
Open DV Discussion
Old September 28th, 2003, 07:44 AM   #1
Glue for Foam ?
I got a Pelican 1610 for my PD150 .. now that I have plucked away all the necessary foam, I was wonderign if anybody knows of a good glue I can use to fuse the 4 layers of foam togueder :)
cheers
PD150
Carlos Rego is offline   Reply With Quote
Old September 28th, 2003, 08:25 AM   #2
3m Super 77 spray adhesive works well, but don't get it all the way to the edges and take care that it ONLY goes where you want it to be. I've done upholstery and foam and "ozite" cabinets for PA and this is pretty decent stuff and the least messy of the choices, but you still need to respect it. The other "industry" stuff makes spider webs that float everywhere while your trying to work with it and it'll drive you nuts unless the air is dead still around you.
If you get ANY type of foam adhesive on an open surface it'll stay a bit tacky almost forever... eventually warranting a remedy or else a short stay at the mental hospital.
I should add that unless the four seperate layers are a problem I'd accept it as four layers. Does everybody who buys this case try this idea or do they forget about it and accept the layers? The suspension effect of the Pelican design is probably more effective as layers anyway... once you unify those layers you'll have a lateral "rigidity" that wasn't there before...
Matt Gettemeier is offline   Reply
