What do these cable TV specs mean? - Page 2 at DVinfo.net
Open DV Discussion
Old March 20th, 2009, 06:59 AM   #16
Originally Posted by Heiko Saele View Post
The SMPTE are the ones FCP creates in play out mode, the ones with the extra color boxes. They are also 100/75 on the color bar part.
You can create 100/100 EBU color bars with FCP from the "other bars and signals" menu, but you will see immediately these look way oversaturated.
I'm not clear on what 75% SMPTE color bars are. Are the FCP bars from the Video Generators wrong and the ones from Print to Video right?
Old March 20th, 2009, 08:02 AM   #17
Put the bars you want to use on your timeline, and check the reading on your waveform monitor & vector scope. You should immediately be able to tell.
David W. Jones is offline   Reply
