Movie premiere... will this work??
Hi there!
I have a movie premiering a month from today, and I'm trying to get my tech ducks in a row. The theater that is showing it has this for a setup: DL.1 Digital Light - Digital Lighting - Products - High End Systems (it's either the DL1 or the DL2) Has anyone heard of or had any luck with this thing? I am limited to a VGA input, so it wont project hi def correct? (the movie was shot HDV) My plan is to export the movie as one FCP Quicktime, then de-interlace the entire thing in one pass through.. Any help, advice, tips, ANYTHING would be great as the stress is starting to mount! Thanks, -Andy |
First, if you are really stressed a month away you will be totally burnt by the time of the event. Don't waste mental energy worrying.
That projector has a maximum resolution of 1024x768 so it is near 720p resolution so you likely can project HD from a computer whose media player will downsize to your projector acting as a VGA monitor. You should also be able to make a DVD and play that from a computer or DVD player into the video inputs on the projector. I doubt any projector would lack basic video input capability. If you can, bring both your computer and a DVD. If you must use their computer, find out its capabilities as HD is too much for some machines. To make it easier to play from a computer you might want to render to 720p to bring down the data flow. |
Thanks Marcus,
I appreciate it. Maybe 'stress' isn't the right word.. excitement? Anticipation? Stress is just part of the emotional rollercoaster. I'm going to export a bunch of 1 minute clips with different settings and try them at the tech run through.. but what do you figure will work best? I'm guessing a de-interlaced self contained FCP Quicktime and using the projector as a video playback window? |
That sounds like a good plan. Use whatever works. I don't know your computer's specs so I can't give any more advice than to use a codec and resolution that hopefully won't overwork the machine. You might want to use one clip with different color corrections to see what looks best.
