time lapse tips
I'd be interested in hearing some advice for good time-lapse shots....
1. What are the best settings for your interval recording?....how long record-run/minutes? 2. What are the best setting when editing?....like maybe the first 5 frames from each exposure? 3. I know there are a wide array of software differences but what sort of work-flow is used to edit the frames you want to use from each recorded sequence?....and how do you get around(or do you?) the auto-indexing of capture software that will assign a scene for every second captured in this case? 4. What are some tips for shooting time-lapse in regard to protecting the cam which is left for long periods.....Like what do you do?....bring a good book and sit in the car with the cam within a close proximity? thanks all in advance.... |
#2 | |
You need to take a series of still pictures, use a still camera. You'll get a much higher resolution from a $200 camera than from a $10,000 camcorder. Get a reasonably good digital still camera for your time lapse. J. |
I disagree re video vs still camera. Many camcorders these days have still image capability. I have created some very pleasing timelapse recordings with my HC1 using the memory card. I use a controller to trigger the capture via LANC.
Recording to tape as video has an advantage (for short periods - less than a tape's worth) - you get every frame and can choose your interval in post rather than having to calculate/guess everything beforehand. |
Interval recording time varies depending on subject, just like shutter and aperture depending on the desired effect.
Lately I have been setting the intervalometer to trigger a 3 shot bracket for HDR time lapse work on a dual axis motion control head. This gives great high definition panning time lapse shots. |
#5 | |||
To try and answer your questions...
My ADD prevents me from capturing more than about 10 minutes or so. I did once leave my camera in a field and walked the 1/4 mile to get my car and drove back. No worries. Generally speaking a rain cover will keep most of the ambient schmutz out. If it's hot or very sunny, an sun umbrella couldn't hurt. Just attach it to a c stand or something like that. Common sense will tell you what you should do. |
