NTSC Mini DV converted favour? at DVinfo.net
Open DV Discussion
Old December 12th, 2008, 06:10 AM   #1
HI there....this is a bit a personal favour actually! I recently returned from a skydiving course in Florida, and was given the video tape from some of our jumps. However, didnt really give it much thought, and I cannot play it as it is NTSC format. Doh! Would anyone be kind enough to convert it to PAL for me, or to digitise the footage so I can have it as an AVI etc. ? WOuld be really handy if someone can help me out? : )
Matthew Stokes is offline   Reply With Quote
Old December 12th, 2008, 08:05 AM   #2
If you cannot find anyone closer, I'll do it for you. Just shoot me an email.
Old December 15th, 2008, 01:41 PM   #3
Thank you for the offer...Im guessing you are in the US? I guess I can't digitise the footage for you to download? Wasent sure if you then put this onto tape that it would play normally on a NTSC player?
Old December 15th, 2008, 02:12 PM   #4
Images: 18
Hi Mathew.............
From memory, most, if not all, VCR players in the UK will play NTSC material on standard UK tellies.
You should be able to take a component/ RGB (whatever) out from your VCR and feed it into whatever your weapon of choice is for capture/ editing.
Can't be more specific without having more info about what you have available.
CS
PS: Just saw the "mini dv" bit in the title. If it is indeed mini dv and not a VHS tape, that's a different kettle of fish altogether.
Which is it?
