Illustrator Q: can't move obj in layer at DVinfo.net
Open DV Discussion
Old August 11th, 2003, 10:48 AM   #1
Air China Pilot
This has been bothering me since I've started using the Layer function in Illustrator 10.
I create a layer.
I put an object in the layer.
Sometimes (and I can't figure out when this is the case), I will try and move the object normally with its layer activated. But I won't be able to! I will drag it, and then when I let it go, it will return.
If I select the layer above it (or any other layer), and then try and move that object, I can!
This is driving me nuts.
Someone tell me how to stop doing this.
Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery
Keith Loh is offline   Reply With Quote
Old August 15th, 2003, 08:51 AM   #2
i actually tried this one for like an hour yesterday. trying to duplicate the error. i couldn't.
this would be a question, if you haven't already, to post on adobe's forums. i always get an answer on there if you can't find the issue you're looking for.
http://www.adobe.com/support/forums/main.html
Jeremy Martin
Uhrwerk.nu
Jeremy Martin is offline   Reply
