Capturing DV with USB
Can I it or do i absolutly need a firewire port.
Premiere doesn't see it and when i switch from CARD to TAPE on the cammy XP stop recognizing the cam. Thanks a lot guys for the info and help |
Hello Philippe,
It is not possible to capture DV through the USB jack. USB doesn't have a video recognition layer. You must capture DV through FireWire. Adding a FireWire port to your computer is simple and inexpensive (usually well under $50USD). Hope this helps, |
Thanks a lot Chris ,
Guess it is time to buy that new Sound blaster Audigy WITH firewire port , don't you think !!! ;) |
USB to Firewire adapter
Has anyone tried this adapter
Pixela 1394 to USB 2.0 Capture Cable. Transfer your camcorder video to your PC or laptop via USB 2.0. One of a kind product! Thanks |
#5 |
It converts the DV to MPEG-1 (not even MPEG-2!) and that's what you capture.
#6 |
Man, I *never* thought I'd see the day arrive when the "USB to FireWire adapter" became a reality. For the longest time, this idea was in the realm of the "VHS to 8mm adapter" and the "Diesel to gasoline adapter." Amazing. Still can't recommend it for the reasons John points out above, but it's worth noting that thirteen years after the advent of FireWire, this thing has finally happened.
#7 |
I will never forget my high school tv teacher wanted to explain to us that just because there is an adapter it doesn't mean it would work. He used an example of a garden hose to power outlet adapter, he made one at his house and brought it in and asked us if it would work.
They obviously woudln't sell it if it didn't work, but its not really an adapter its converting the dv signal to something else. Either way, I wouldn't trust it. |
#8 | |
#9 | |
Shaun C. Roemich Road Dog Media - Vancouver, BC - Videographer - Webcaster www.roaddogmedia.ca Blog: http://roaddogmedia.wordpress.com/ |
#10 |
IEEE 1394 Cable ??
I'm being forced to use my eMachines w3623 Desktop as an editor since my AlienWare a51 m7700 Laptop melted down a couple days ago.
So... is there an IEEE-1394 4-pin cable that can run from the XL1s to a USB v2 port? |
#11 |
i start to understand why your Pc melted down :-)
#12 |
Nope, the IEEE1394 is a FireWire port and cable. USB V.anything is a totally different animal completely. Don't even THINK of connecting one to the other directly, even if you can manage to force the connectors together..
Good news, Cousins! This week's chocolate ration is 15 grams! |
#13 |
Unfortunately, that partuicular AlienWare model has over-heating issues... will be sending it back to them for a complete makeover as usual (free of charge thankfully).
That figures... any alternatives? What about going tapeless by attaching an external harddrive to the XL1s, recording to it, then transfering it using the USB v2 sockets or some other method? |
#14 |
Well you can't just record to an external hard drive. If you have a FireStore or something similar, you can, but not just any old hard drive. You can buy a FireWire PCI card for your computer. It should be a straight forward install.
#15 | |
USB to FireWire DV Adapter - NTSC - US Version However, it costs $120. You'll be *much* better off if you simply add a $30 FireWire card to your computer. |
