"Fake HD" on Vimeo at DVinfo.net
Open DV Discussion
Old September 2nd, 2008, 09:44 AM   #1
"Fake HD" on Vimeo
This might be common knowledge, but I just figured it out on my own so...
If you export your video clip using the HD specs (1280x720) and upload it to Vimeo you will get a much larger view than if you use the SD widescreen suggestion. Of course, Vimeo thinks it is HD and labels it as such and it won't look quite as good as a real HD clip, but I think the larger size makes for a nicer presentation. What do you all think?
You be the judge. I've uploaded two versions of the same video, standard SD widescreen...
Chincoteague and Assateague on Vimeo
...and "fake HD".
Chincoteague and Assateague - "Fake HD" version on Vimeo
http://mikepulcinella.com/portfolio.htm
Check out my work!
Michael Pulcinella is offline   Reply With Quote
Old September 7th, 2008, 04:18 PM   #2
I have to agree. The larger looks great! Good find.
David Delaney is offline   Reply With Quote
Old September 7th, 2008, 10:37 PM   #3
Ditto here, Michael - bigger is better, with improved resolution (assuming the user's PC and bandwidth can keep up).
Thanks for the tip!
Regards, Michael
Michael Nistler is offline   Reply
