Fixing a visual "oops" of your set in post at DVinfo.net
Open DV Discussion
Old June 25th, 2008, 01:54 PM   #1
This may be obvious to most of you. However, I wanted to share this to perhaps help someone else in a similar predicament. I also wanted to see if anyone else has had a different solution.
I recently shot a skit for a "spoof" commercial. It was shot in a kitchen. In one shot the actor is standing in front of a black "side by side" refrigerator. I did not notice during the shoot... but there was a dent in one of the two doors about a foot from the actors head. The dent showed up like a sore thumb in the video. A re-shoot was out of the question.
Fortunately it was a tripod shot and at no time during the shot did the actor or any part of her body move in front of the dent. So... I took one frame shot of the scene and had a Photoshop proficient buddy fix the dent. I then used an 8 point garbage matte in P-Pro CS3 on the photo-shopped image to key out the part where only the good video would play underneath. I simply laid the video track under the matte. Presto... when the video is played you would never know the dent was there.
Any similar experiences? I'm guessing I'm not the first to do this.
Tim Bickford
Tim Bickford is offline   Reply With Quote
Old June 25th, 2008, 02:27 PM   #2
I've used this trick to fix wayward boom mics that slip into the shot. Another point to remember is to keep the same F-stop. Anything on auto iris will give it away.
Edward Phillips is offline   Reply With Quote
Old June 25th, 2008, 06:46 PM   #3
Not knowing what software you're using, but in most NLE systems, you wouldn't really even need to go to all the hassle of shooting and using a digital still.
Just duplicate a COPY of the current video track to an adjacent video track such that the second copy of the shot sits in front of the original one.
Then CROP the foreground shot to an area right above or below or adjacent to the blemish where the door texture is undamaged.
Then just slide this digital bandaid over the bad area.
Presto. No more dent.
(It even works on moving shots, tho you have to keyframe the band-aid in order for it to track the shot motion.)
Old June 26th, 2008, 04:05 PM   #4
The clone tool in After Effects can be useful for something like that. Depends on what the dent looks like. It works just like the clone tool in Photoshop.
Clone from a clean section to cover up the dent, and have that effect applied to all the frames in the clip.
Dean Sensui
Old June 27th, 2008, 02:16 PM   #5
These are all great ideas. I appreciate the feedback and will add these to my bag of tricks.
Tim Bickford
