HD-SDI Cable Length at DVinfo.net
Open DV Discussion
Old April 19th, 2008, 07:06 PM   #1
HD-SDI Cable Length
What is the maximum length that HD-SDI Cable can be run? Would a 500ft run be fine or would it loose too much signal?
Sorry if this is in the wrong catagory
Andrew Fraser is offline   Reply With Quote
Old April 19th, 2008, 07:22 PM   #2
It depends on type of signal and wire gauge.
You can check here:
http://www.extron.com/company/article.aspx?id=lvdg_ts
Doug Okamoto is offline   Reply With Quote
Old April 19th, 2008, 07:42 PM   #3
so 285ft maximum acording to that site, or 328 acording to the Pansonic site.
Old April 19th, 2008, 07:58 PM   #4
this should do, acording to www.whirlwindusa.com/ftp/tech/beldtb65.pdf using 7731A cable a 540ft length can be acheived (page 16)
Old April 19th, 2008, 08:01 PM   #5
300 ft is the general rule. Though sometimes I get a week signal that won't make it that far. A reclocking DA has saved me a few times on longer runs - 500 ft.
http://www.aja.com/html/products_converters_HD10DA.html
Tom Majeski is offline   Reply
